Gauges
Old Oct 19, 2001 | 04:27 PM
Racnoth's Avatar
Gauges
Would like to replace all the gauges in whatever F-body i eventually decide to purchase....All Gauges will be Autometer Phantom Series, anyone do this before? Hints/tips?
Old Oct 19, 2001 | 09:23 PM
valu8or's Avatar
Take a look.
1986 IROC
New Crate 350 w/Vortec Heads, Edelbrock 2116 Vortec Manifold, Edelbrock Performer 2102 Cam, Edelbrock 1406 carb, Hedman shorty headers, Flowmaster Catback, Rebuilt 700r4 w/vette servo, etc..
[This message has been edited by valu8or (edited October 22, 2001).]
Old Oct 19, 2001 | 10:12 PM
Racnoth's Avatar
you have any more pics of this? Maybe a write up on it or anything? What did you use for the new gauge housing? Ect, ect, ect...
Old Oct 20, 2001 | 01:10 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I want to do something similar. I want the 5" speedo, but I want a silver tach with a shift light on the dash. I want to put oil, H2O, fuel level, and volts in the right side of the cluster, where valu8or has his tach. I would then put the turn signal, and high beam indicators in the middle. Like this:
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust, Dynomax Bullet Mufflers, T&R Motorsports custom air intake, Bald tires
Old Oct 21, 2001 | 10:01 PM
un4givin89's Avatar
This looks interesting and promising, however I don't like the one in the center.. hummm
un4givin89
Old Oct 22, 2001 | 11:50 AM
valu8or's Avatar
I also liked that one, however the four lower gauges would not fit into the existing dash opening and I did not want to bastardize the whole dash. That was version number 6 and the one in the car is version 22. I utilized abs plastic from a local plastic supplier. I looks exactly like the plastic already in the car and was pretty cheap (I think $25 or so for a 4' x 8' sheet) after I finally found a supplier to sell it to me. The good thing about this is that I can put the old dash back in at anytime with very little effort. The bad thing is the total cost for the gauges and sensors needs was about $700. Oh well, just throw good money after bad into this damn thing. hahaha
Old Oct 22, 2001 | 03:40 PM
un4givin89's Avatar
DAMN, there goes this idea I had,
un4givin89
Old Oct 22, 2001 | 08:22 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I just put phantom guages in my car.
I have 5 inch tach and speedo, and 2 1/16 fuel, volts,oil press, water temp,and fuel pressure. I have the fuel level and pressure on the a pillar in a pod. I have the tach and speedo in the origional location with the volt meter between them. I didn't like having the oil pressure and water temp under the tach and speedo so I removed the cigarette lighter and the defroster switch and made a plate to cover the opening. Then I mounted the water and oil pressue guages in that spot. I think that it looks pretty good. The most important guages are easily visiable and not covered by the steering wheel. Sorry no pics yet.
And yes the conversion was expensive around 600 dollars for the guages.
Hope this helps .
Kory
Old Oct 22, 2001 | 09:28 PM
johnsjj2's Avatar
Car: 1991 Z-28
Yeah, the cost gets me too. I had added up about $665 for the gauges. I am still trying to justify the cost as a X-mas, Halloween, Thanksgiving, and New Years present to me!! I like the looks of un4given's idea, but the steering wheel would get in the way. I would also like the look of the tach in the dash, but I just can't get over the race car look of the tach on the dash. But then again I really don't want to put a hole in my perfect upper dash. Oh well, I've got nothing but time and paper.
Joshua Johnston
1991 Z-28
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
