t top problem
Car: 1986 camaro iroc z
Axle/Gears: stock
t top problem
ok i dontk now if this goes here but here goes. my t tops on my 92 firebird have this weird covering on them i cant seethrough them any more its gray and rough feels a bit like a chalk board anyone know what it is * it did sit in a drive way for 2 years but dont they all * and if anyone does doens anyone know how to remove it or do i replace them?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: t top problem
Maybe they were covered with something,maybe a primer.Do you have a pic??
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: t top problem
Dust? Pollen? Both? Have you tried washing with warm soap and water to see if comes off? Gentle scraping with something non-metalic?
Axle/Gears: stock
Re: t top problem
yes i have it doesnt come off its like someone painted them but its so uneaven there are white spots and grey areas i tried to use 2000 grit wet sand paper ( my next door neighbor does fiber glass) and it smoothed out but wont come off
Axle/Gears: stock
Re: t top problem
im being told its sun damage. that its salt damage. that someone tried to paint them.. idk. the one i sanded the light seems to come through a little bit more but i still cant see through
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: t top problem
your best bet is to find a new set and pitch those..they are acrylic and you most likely will never be able to see through them again..85-i believe 89? not sure on the last year..came with glass tops..find a set of those and you will be golden..
Re: t top problem
I recommend you go to glass tops. Easy to find at the junkyard and not expensive.
DONT pitch the old ones, though. The racers like them because they're lighter. And you can sand and paint them body color for a cool hard-top / t-top look.
Car: 1992 W68 Firebird
Engine: 305 5.0L V8 TBI
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: t top problem
Yes they are LEXAMAR (the correct name) tops and sad to say they are shot!
Your best bet is to get a set of glass tops as they are found used very reasonable.
For the cost of materials and your time to paint or other methods to fix them up
a glass set is the best cure IMO.
Your lucky they are not the C&C tops. Parts and replacements are getting hard
to find.
to find.
Engine: 5.0 EFI
Re: t top problem
https://www.thirdgen.org/forums/exte...-firebird.html
PM this guy,he's breaking up a Firebird and he's a good seller,very reasonable
Re: t top problem
6 liter eater makes a targa setup. Not sure if they make em for third gen or just forth but you can get them in fiber glass or carbon. Why not paint them a nice accent color? If you are looking for clarity however I agree with the others on getting a glass set.
Car: 1969 RS Z28 X33 Norwood built
Engine: 383 Stroker
Transmission: T10 4 speed
Re: t top problem
I had a 91 RS with those Tops. I hated them with a passion. They scratched so easily. The glass ones on my 87 IROC are great! I agree with other posters about getting some glass ones.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: t top problem
assembly that are rare and hard to find.
Take out the whole unit and piece it out for the best $$ return.
Axle/Gears: stock
Re: t top problem
im gona get glass ones and paint these the color of the car or maybe paintthem black and shine them up real good
Car: 84 camaro Z28
Transmission: borg warner T5
Re: t top problem
Street Lethal
Apr 30, 2019 12:14 PM
