86 Z third brake light howdo you take it off and can you leave it off?
Old Nov 14, 2001 | 03:05 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
How do you get it off? If I can't leave it off I have to paint it. Thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Nov 14, 2001 | 03:28 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
don't know about the camaro, but my 87 firebirds have 2 screws holding them on from the outside. thru the lens.
You might want to remove the spoiler. for a better paint job.
John
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera (driver)
83 Camaro
83 T/A
Old Nov 14, 2001 | 03:30 PM
okfoz's Avatar
or are you talking about the cyclops on the rear hatch glass not in the spoiler?
If no one here knows, your library might have books on your car. look for the GM sevice manual for your year camaro.
John
Old Nov 14, 2001 | 05:57 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
in 86, the 3rd brakelight on camaros was at the top of the hatch, not the spoiler. i have no idea how to take it off though
Old Nov 14, 2001 | 06:32 PM
prepz28's Avatar
the black cover comes off with the two screws on top. i dont think you can remove the rest of it.
Old Nov 15, 2001 | 06:39 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
Two screws go through the glass to mount the brakelight. I know, mine fell out when the hatch glass broke.
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
