roll bar
Car: 85 Trans Am WS6
Engine: 305HO L69
not if you want it to be functional. if you just weld it to the floorpans, put a good amount of pressure on it and it will go straight through the floorpan. for it to work properly, you need to weld it to the frame.
i was goig to weld it to the frame but i cant find it
i found it in the back but whare the mane bar is (the back seets) i just dont know whare the frame member is do u know and in the front i know that there is no frame so i just weld the bar to the floor beside the door thinks for your help
<font face="Verdana, Arial" size="2">Originally posted by Diabolical:
not if you want it to be functional. if you just weld it to the floorpans, put a good amount of pressure on it and it will go straight through the floorpan. for it to work properly, you need to weld it to the frame.</font>
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
If it is not welded to the frame, you have to use 6x6x1/8 (not 1/16) plates.
Miles
88 427 Big Block Camaro
(Best 1/4) 12.18 @ 113mph 1.75 60ft
(Best 1/8) 7.76 @ 94mph 1.72 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 posi carriers for sale for 9 bolts
www.koolmeister.com
Miles
)www.koolmeister.com
darwinprice
17
Oct 11, 2015 11:51 PM
