It's the crack from He!!,HELP!!!
Old Nov 16, 2001 | 05:12 PM
Blucamaro's Avatar
Ok,Here's the problem,I noticed that my steering was kinda funky,Like it didn't want to turn that well sometimes.Well,Today I noticed that the inner wheelwell where the steering box mounts to has a nice size crack and starts to flex when i turn the wheel.Do any of you think i can sheet metal it all up and it will be ok,or should i try to weld the crack?the crack goes 3 inches across the top and a few inches down.
Old Nov 16, 2001 | 06:39 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
I just welded mine up.There were five 3 1/2 inch breaks in the frame.
Old Nov 17, 2001 | 10:07 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
get a wonder bar. it reinforces the subframe by conecting the two sides of the car together and stops what happened to yours.
by the way, weld ot up before installing the bar.
My Ride:
1987 IROC-Z 355 TPI
2.73 posi
K&N air filters
polyurithane front and rear anti-roll bar bushings
3 inch exaust
DF88ECU pannasonic cd player head unit
soundstream audio 200w amp
JL audio 12" subwoofer
pioneer 6x9 rear speakers
KILLS:
89 mustaing GT
97 civic type R
96 s-10 SS
94 integra type R
98 cavalier (this guy must have been high, it was a 4 cyl.)
89 caprice
90 camaro RS 305 tpi
95 mistubishi 3000 gt VR4
many more slow stupid cars.
Old Nov 18, 2001 | 06:50 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Install a "wonder bar" first.Then have the cracks welded up.
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
86IROC112
Nov 7, 2015 06:50 AM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
