Headlight adjust
Old Nov 18, 2001 | 07:27 PM
Faught's Avatar
Headlight adjust
My 85 bird seems as if the headlight beams need adjustment. I know how to do this, but the correct angle is the problem. does it need to be professionally done. I remember there used to be an adjustment device one could get at an AP stores, do they still have them ?
Old Nov 18, 2001 | 08:05 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
i don't know about birds, but the "adjustment device" for my camaro is a phillips screwdriver.
87 Camaro LT
bone stock 305 w/ 700r4 0-60: 3 minutes
mods to come:
ground effects
93 camaro seats
99 camaro center console
91 z28 rims
white 145mph iroc gauges
Old Nov 18, 2001 | 08:11 PM
Faught's Avatar
Realize this! I was talking about something that can tell me the proper alignment for the beam itself....
Old Nov 18, 2001 | 09:02 PM
scauffiel's Avatar
I just pull up to a garage door in the daytime and make sure they're both at the same level and hitting at the same spot (relatively) while sitting in the car. Then at night, I'll go out and make sure it's hittin' where I want it to be height wise (i.e. how far down the road I want the beams to go.)
Steve
Steve's Trans Am Temple
Old Nov 19, 2001 | 02:10 AM
Jza's Avatar
Jza
Look at my tech article in the tech article section (upgrading headlights). It explains the "25 foot" method of adjusting your headlights. You want the beam to drop two inches every 25 feet.
Old Nov 19, 2001 | 09:54 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I usually adjust my headlights to hit my knees at about 30 feet.
John
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera (driver)
83 Camaro
83 T/A
J-money
Jan 4, 2019 09:45 AM
Nervous2
Oct 8, 2015 10:53 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
