Thinking of getting 4th gen wheels...Spacers?
Old Nov 20, 2001 | 11:05 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
If your car came stock with the 16x8 wheels, would you need different spacers for say the salad shooter 4th gen wheels? As long as they are 16x8 wheels, they should fit just fine right?
1992 Polo Green RS 3.1L K&N conical and working on the ram air....
"Yeah, it's a V6 SO WHAT!?"
Old Nov 21, 2001 | 02:28 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
yeah you'll need spacers for any 4th gen wheels. i'm not sure what size you need, but i'm pretty sure that all the different styles4th gen wheels would require the same size spacers.
87 Camaro LT
bone stock 305 w/ 700r4 0-60: 3 minutes
mods to come:
ground effects
93 camaro seats
99 camaro center console
91 z28 rims
white 145mph iroc gauges
Old Nov 21, 2001 | 04:49 AM
Blown_n_Injected's Avatar
The spacers are huge...and expensive..bout $300 for all 4...I have 4 Salad Shooters for sale if u need em. Perfect condition $200 in Houston.
Old Nov 21, 2001 | 06:21 AM
syxx's Avatar
the spacers you would need are like 2 1/4" all the way around. I'm doing the same thing as you(getting some 4th gen wheels). Although I am looking into getting a drum brake rear end off of a 4th gen, killing 2 birds with one stone(no spacers needed and newer/higher rear gears). i'm looking around to see where i can get a rear end cheap so far it's about 2 bills.
Syxx
Old Nov 21, 2001 | 02:15 PM
Diabolical's Avatar
Engine: 305HO L69
i thought it was like 2.25" for the front and like 1.5" for the rear?
Old Nov 21, 2001 | 02:37 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
2-1/4 for the front and 1-3/4 for the rear is what you are supposed to use.
I used 2-1/4 all the way around, so I could sell me rear set to someone when I get my 4th gen rear bolted on,
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Nov 21, 2001 | 03:50 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
technically what you need for an exact factory look is 2.15" front spacers, and 1.5" rear spacers. I'm running 2" all around, and it's working great. The fronts have no clearance problems, and the backs look mean sticking out a hair (as do Zepher's)
IROC + Paxton = fast
GT + Eaton = GTP = fast
Old Nov 21, 2001 | 06:52 PM
camaro6spd's Avatar
ok, not may car is lowered 2", would the 2" spacers work for me or whould I go for the 2.25. Is there anyway to make these in a machine shop? Then I could get the 2.15 and get them cheaper.
midge54
Jan 29, 2017 07:00 PM
Casey Meyers
Mar 2, 2016 10:46 AM
sreZ28
Aug 14, 2015 07:48 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
