paint question
Old Nov 23, 2001 | 10:12 AM
Bluebird's Avatar
Car: 1991 Pontiac Firebird
Transmission: 700R
paint question
Ok, this next spring if I can afford
it, ,I want to get my 1991 firebird
painted.
I don't want paint over paint..
How much should I expect the cost for
the entire car?
it's blue metallic
Old Nov 23, 2001 | 10:14 AM
Bluebird's Avatar
Transmission: 700R
p.s. I know the picture looks as tho
it doesnt needd paint.. but there is
spots where the paint is flaking off,
plus there is rock chips, etc.
Old Nov 23, 2001 | 02:57 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Maybe 1500 to $2000.00 for a real good job that gives you a right to complain about microsopic dust. If you do all the prep work you self you might just save alot of money. You car doesnt require any body work does it? They will get you on that. Do you know how to wet sand?
89 Formula Firebird
Red with T-tops
5.0 305 FI
Soon to be a 400small block
Old Nov 25, 2001 | 10:20 PM
Bluebird's Avatar
Transmission: 700R
it only needs body work in one spot
on the back bumper, backed into a post
cuz of my tinted windows when I first
got them tinted.. couldnt see.. backing
up at night.. haha..didnt dent or anytihng
fiberglass bumper, it just spiderwebbed
a spot about the diameter of the rim of
a pepsi can, but I asked a body shop bout
fixin just that part once, an they said
150 bucks for that part.
Old Nov 25, 2001 | 10:57 PM
82 TRANS AM's Avatar
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
What do you mean by "don't want paint over paint?" Do you want it stripped? If so, thats about 6-8k. A good paint job with good materials (on top of the factory paint) would go for about $3500-$4000.
Good
fast
cheap
Choose any two.
Also remember that decent materials for a job like that runs $500-$1000. With that in mind, hows that $1500-$2000 paint job gonna be?
You could save yourself some hard cash by taking everything off (handles, belt moldings, bumper covers, ect. off yourself, and some preping too.
Kenney
82 Trans Am WS7 notchback
83 Trans Am WS6 T-tops
Painter @ Chevy dealer
GM junkie
Old Nov 27, 2001 | 04:56 PM
Bluebird's Avatar
Transmission: 700R
If they paint over paint, its just gonna
come off down the road...
I wanted primer, then paint..
your tellin me its gonna cost me 8 grand
for that!?!?
Old Nov 27, 2001 | 05:30 PM
Car: 82 T/A WS7
Engine: Pontiac 400
No, 6k-8k for a stripped to metal show quality. If it's prepped correctly, the base coat will stick to your factory coat just fine. A primer/sealer should be applied to any surface that may need it, and sandable primer to any repair areas, like dents w/filler, or sanded through areas. You want as little material as possible to get the job done. If for example, your door is perfect, no dents, scratches, chips. Scuff/sand it flat and put the new blue basecaoat right on top of your factory blue. This keeps the paint bill down, and your door won't have a ton of paint on it, for no good reason.
My advice is to take EVERYTHING off yourself. GFX, door handles, belt moldings, covers, mirrors, side markers, everything. This will save you a ton of cash. Cash you could be spending on better paint/painter or mod parts.
Nice looking car BTW, Good luck.
Kenney
GM junkie
Old Nov 29, 2001 | 11:09 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I don't mean to step on anybody's shoes, but if you get a regular old body shop production paint job, it will run you from $1500-$2500. That is painting over paint. Now, there is nothing wrong with painting over paint, if there were, you would be able to lay down more than one coat. I have four layers of different paint on my T/A, and two on my Elcamino, and two on my Riviera. I used to paint show cars for a living and I would charge atleast $8000 for a show quality paint job. All the way up to $35000. I only stripped all of the paint off when I needed to. But your rear bumper doesn't even sound like a problem. Just some cracked paint. They shouldn't charge any more for that. If they do, walk away.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Dec 2, 2001 | 07:06 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
I've got a question for you guys. I'm looking at what doing what blubird is doing. If I prepped that car (all sanded down to 800 grit, oil free, and ready to spray) how much could I expect to pay? Also how much do racing stripes add to the cost? I plan to wetsand and buff myself too. And yes I'm broke and trying to save every dime I can.
Nice ride Bulebird.
-Matt
1984 Camaro Z28 - Black w/ Grey int.
-GMPP 350 (72cc heads, 8.5:1 CR, & .390 intake/.410 exhaust cam)with Edelbrock 600 Carb, Edelbrock Preformer RPM intake, AC Delco plugs, 8mm AC Delco wires, 14" Accel filter, Edelbrock Chrome valve covers, breather, and Air cleaner.
- Profesionally Built Turbo-350 with 2500 RPM Stall converter, Hurst shifter, & one wicked shift kit.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
-Comming Soon:
3.73's, MAC Cat-Back, hollowed cat., B&M Megashifter, & Paint: Navy Blue Metallic w/ Silver strips
Pics & more at: http://members.fbody.com/flashz28/
Old Dec 5, 2001 | 10:33 PM
Bluebird's Avatar
Transmission: 700R
So do you guys think it will be
alright to paint over the paint then..
I was a little worried bout that cuz
of the couple of spots on the top behind
myh t-tops the paint is peelin off.
also.. I wantedd to have like lighter
blue ghost flames across my hood and along my fenders.. is that going to put
the pricee way up in a ridiculous spot?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
