Antone have a way to secure the front of the headliner?
Old Dec 4, 2001 | 05:10 PM
Hulk0202's Avatar
I bought one from thirdgenparts for $10 since I live two minutes down the road. Anyway, the two front clips ripped out. I have the visors screwed in which keeps it up but it sags in the middle. Anyone else have this problem.....and solve it? Thanks for any help.
Old Dec 4, 2001 | 05:37 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
you can buy thoese plastic rivits from the dealer or a place like NAPA.
1989 Iroc-Z 5.7 350, Blue, T-Tops
Lightly Moded:
Edelbrock Headers, Rebuilt B&M 700R-4 Tranny, Higher Stall Torque Converter, Airfoil, 3.4 w\posi, K&N's, Ported & Polished Plenum
-- Blue LED Bakelite Dash & Climate Control
- I am just some 17 Year old spending every dollar I make on my car.
Old Dec 4, 2001 | 06:25 PM
1986CamaroSCteen's Avatar
My headliner always sags, and its sensitive to temperature, always sagging.. Its not original, but it came with the car when i bought it, you can take small pieces of cardboard or plexiglass, and shove them up under the plastic trim in the car and it should hold that headliner tight, but, it may be temperary...
Old Dec 6, 2001 | 08:59 PM
elizabeth's Avatar
If I understand correctly your headliner is hanging down just enough to be irritating between the visors. I used a 2 inch piece of velcro on mine. Use some heavy duty adhesive ( do that kind of work so I used high temp glue for headliners) then seperate the velcro apply adhesive and install one piece to the roof and one piece to the underside of the headliner itself. Leave the 2 pieces apart overnight then push the headliner up into place. It won't fall again.
PS.sticky backed adhesive won't hold
Old Dec 6, 2001 | 09:36 PM
bigals87z28's Avatar
Car: Check The Sig
i think chevy/gm should of just make that plastic...i gota get one... some how moisture got to the cardboard and its now rotted out... so i cant even put up the fabric. if some one could tell me a good place to get headliner board that would be great... i looked at nextgen put that whole thing is overpriced... thanks fellas
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
zayne0
Aug 24, 2015 07:22 PM
TheJoeY88
Aug 13, 2015 06:51 PM
