Orange peel
Old Dec 10, 2001 | 08:35 PM
rodder's Avatar
Orange peel
How do you keep from getting the crinkly orange peel look in your paint? Ive been told by 2 different painters to wet sand like crazy & put more thinner in your paint. Is either one right???
Old Dec 11, 2001 | 07:07 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The quality of the paint and its addatives, along with weather conditions, spray gun, air pressure, air quality and acts of *** all depend on how much orange peel you get. Just put the paint on as heavy as you can without runs, and hold the gun close enough that it goes on wet. That'll allow it to flow as best as it is capable of, then you'll have to wetsand and buff to get it smoother.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Dec 11, 2001 | 07:19 AM
Nightcruzer's Avatar
Car: Trans Am
Even factory paint jobs have some degree of orange peel. The trick IS wet sand, wet sand wet sand and buff, buff, buff. But to wetsand make sure you have enough paint on the car or you will wet sand through to the primer.
Old Dec 11, 2001 | 02:03 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
WETSAND IS THE ONLY WAY TO REMOVE IT BUT AFTER THAT IT IS WORTH IT. CHECK MY SIG. AND YOU WILL SEE THE RESULTS OF A GOOD WETSAND JOB.
86 Camaro Black SS Coupe, T Tops, ASCD Daytona Twin Turbo hood, Flowmaster, Custom Black Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels,new charcoal & gray interior including seats and door panels, leather wrapped steering wheel, shifter and emergency brake, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
'91 RS 5.0 TBI = Waiting to be modded, but has all of the toys inside.
http://www.angelfire.com/sports/niterider/86camaro.html
Morgan_Andre@hotmail.com
Old Dec 11, 2001 | 07:04 PM
HamsterOnaMission's Avatar
some causes that i know of include holding the spray gun too far (why i'm repainting again) or putting on too little paint per stroke(if that's what you call it)or painting when it's too hot, not giving the paint enough time to flow out glassy smooth
paint that's too thick won't flow out as well iether
Old Dec 11, 2001 | 09:16 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
To lay paint flat takes alot of practice. It took me a while to learn, but now it comes easy.
When you shoot paint, you need to make it stick. To do that, squirt one coat, let it get tacky, then squirt another, and so on...
To find out if the paint is tacky, shoot onto the masking, then touch the paint there. When it gets stringy, then you're good to go.
Just make sure that you don't hold the gun too close to the surface, and do hold it at a 90* angle to the surface.
Then, when I wet sand, and polish, the end result is a perfect show winner paint job.
'82 T/A, LG4 based 355, WC-T5, 9bolt posi disc rear, awaiting smog for registration
Elephantismo
Feb 13, 2019 12:51 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
david068513
Sep 18, 2015 10:36 AM
gta892000
Sep 16, 2015 12:40 AM
gta892000
Sep 16, 2015 12:37 AM
