Car going to the body shop Monday
Old Feb 12, 2014 | 03:08 PM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
I'm dropping my 89 IROC-Z off for paint and to repair the damage my wife did from backing into the drivers side fender and door. My question is.... I haven't purchased my new stripes or IROC-Z decals for the doors. So would it be better to wait a while to let the paint cure good... I'm assuming they will bake the car anyway, but would it matter when I had the stripes installed? I was going to do that after I get the car back... to make sure everything looks right. Then take it back and have the door decals installed.
They are installing my new door and t-top weatherstripping after its painted, along with new door pins and bushings. Excited to get it done...
Old Feb 12, 2014 | 04:20 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Car going to the body shop Monday
I would wait. I had new paint on mine and installed the IROC-Z Door decal much later.
My painter used products with solvents not this water base stuff I have seen.
He also suggested the 90 days for decals.
Only a mild soap with nothing else added (no wax) and water to wash the car for just as long.
If you apply wax and other products to the paint before it cures you will smother the drying paint and locking in the ability for solvents in the paint to dissipate.
This says basically the same thing but thought I would add it.
I found this= http://www.ehow.com/about_4679730_ne...#ixzz2t9IBNcxA
Old Feb 12, 2014 | 07:15 PM
85ttopsz28's Avatar
Car: '85 camaro z/28
Axle/Gears: stock
Just curious what just the paint job is costing you. And where you are getting it done at.
Old Feb 12, 2014 | 07:42 PM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
2A Auto Body in Fort Oglethorpe, GA is doing the work... it's costing me 2400.00 to replace the drivers side fender, remove ground effects, front and rear bumpers, stripes, weatherstripping and trim... strip the car, fix any imperfections in the body and paint it base / clear then re-assemble. They are putting the car on jack stands in the paint booth also, so the rockers get a good coat of paint. This includes the door jambs.... and I'm a repeat customer so the owner cut me a large discount.
Amazing shop though, so if any of you are near north Georgia then 2A is the place to go. I'll have pics in a couple weeks
Old Feb 12, 2014 | 07:43 PM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Ron,
Thanks for the information. I was thinking it would be better to wait until the paint fully cures before adding stripes and decals. It will be stored in my heated garage until the weather warms up too
Old Feb 12, 2014 | 08:30 PM
Engine: TBI,5.0
I hope you’re going to document the process with photos.
I did a" prep. to paint" thread showing some of the work being done.
They came out great and since it was a high end paint job like yours ( around here I consider that a high end )there are plenty of steps in the process to take them.
That's a nice price considering what you’re getting. From what your describing if there using a quality paint and clear it would run in the $5,000.00 range around here.
Congratulations on the paint job.
Old Feb 12, 2014 | 08:41 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
I agree with RonUSMC you should wait how long depends on witch hardner they use there are slow -fast slow taks longer to cure but 90 days and your fine
Old Feb 12, 2014 | 08:49 PM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
Im a body tech.we dont wait to put decals on at all.after the car is buffed we have the decals put on even the big ones.they come off the same later if needed.
Old Feb 12, 2014 | 09:00 PM
Engine: LQ4 ls 6.0
I agree when I work in shops we did it to but if you can wait to install the decals and not take a chance of traping solvents why not wait ?
Old Feb 13, 2014 | 09:32 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Its always better to wait if you can, though most collision shops will put on decals after its baked and polished.
Terrell351
Jun 13, 2021 01:13 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kah992
Aug 19, 2015 02:55 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
Amillionoh7
Aug 7, 2015 01:24 PM
