headlight relocation.
Car: 1986 camaro iroc z
Axle/Gears: stock
so i this topic may be covered but i cant find it . i have a 1992 pontiac firebird that i realy dont like the flip ups on it i was thinking of moveing the headlights down into the bumper were the fog lights are 1 is it legal in north carolina 2 how hard is it and do i need new tyle of bulbs to make it fit 3 are there any pop up deletes that have be made or custom made for the 91-92 specificly thank you
Car: 1983 Z28
Engine: 385 Fastburn
Re: headlight relocation.
You could unhook the power to the headlight motors and then just relocate the lights and mount them similar to driving lights. Shouldn't be an issue since you still have headlights, but the performance of said lights would be significantly reduced. Putting them that low would not only cut down on your adjustment range but also make you go dark anytime you came up on a steep grade.
IMO not a safe idea, but a doable one nonetheless.
Axle/Gears: stock
well now ive got the motors fixed but now when you turn the driving lights on but not the headlights the headlights motors come on and raise the housings still whats going on
Car: 1983 Z28
Sounds like the driving lights and headlights are wired together at somepoint. Trace the wires and have a look
Car: 1988 Chevrolet Camaro IROC-Z
Engine: 408 LSx
Transmission: T56 Magnum
Axle/Gears: 3.73 10-Bolt Detroit TrueTrac
I would suggest flush-mounted projectors that would replace the entire headlight housing, like what the RX-7 guys do, but I don't know if the hood angle of the car is too flat to do that.
Car: 91 trans am gta
Engine: 5.0L V8
Transmission: 5 speed
I have been trying to find the same typeof thing, for now I put hids in my drivinglights or fog lamps and I am debating just disconnecting the power to the headlight motorsso they will not go up or turn on. bout really sure how legal that is but I don't care for pop ups, if you think of any other ideas let me know
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Axle/Gears: stock
well change of plans now they come up and i wana keep em still planning on doing the 30 dollar hid conversion for the fog lights to make em brigter but ive run into ap roblem every time i turn the fog lights and running lights on without turning the headlights on the headlights still come up
Engine: 5.0L V8
gumby that link up there was quite impressive, to bad it looks like the guy doesn't want to make any to order.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
But there are more simple mods, redraiff I do belive [ somethin like that, girl with the V6 Bird all decked out in red show car, got on TV once] , did similar but kept stock lids, just cut out the 2-3in high section facing forward [ next to turn signals] when closed and put skinny lights in there, so they shined from stock location but were always closed.
With the power of LED's that small area should be easy to get plenty of light from. Can still put some driving lights down low to help. I run yellow driving lights on everything.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Axle/Gears: stock
yea im gona unplug them till i get the bushines for them and might as well get the button 2 while im at it
Engine: 5.0L V8
Yeah im trying to get a good look at red raifs but can't idk if my phone isn't just loading correctly but when I go on cardomain I only see like 9 pictures from her latest update that's all....
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Redraiff hasn't been on the boards in forever that I can recall. I watched her thread quite a bit for a long time to follow it's progress but decided in the end to keep the pop-up lights. I just need to fit factory fog-lights...previous owner put some sorry-a$$ aftermarket crap that does't work and isn't aligned right when it does.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
was in 09 when she last posted in my build thread.
https://www.thirdgen.org/forums/v6/4...-all-over.html
