Door lock cylinder
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Door lock cylinder
Hey guys. My driver side door lock seized. I went to GM to get a replacement, but the part is apparently discontinued.
Can anyone recommend a good source for a replacement part???
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Door lock cylinder
http://www.trademotion.com/parts/198...ARE&group=DOOR
HVAC
MAINTENANCE & LUBRICATION
MANUAL TRANSMISSION
REAR SUSPENSION
STARTER
STEERING
STEERING COLUMN
UNIVERSALS & REAR AXLE
Part # / Keyword Search Clear Search
Searching for: keys 1 - 5 of 5 Parts
BODY HARDWARE / DOOR / GLASS & HARDWARE / Cyl & KEYS Cyl & keys Left
MSRP Online Price $26.78 $16.71
BODY HARDWARE / DOOR / GLASS & HARDWARE / Cyl & KEYSGMPARTSCHEAP.COM
HVAC
MANUAL TRANSMISSION
REAR SUSPENSION
STARTER
STEERING
STEERING COLUMN
BODY HARDWARE / DOOR / GLASS & HARDWARE / Cyl & KEYS Cyl & keys LeftMSRP Online Price $26.78 $16.71
Engine: 5.0 EFI
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Did you try spraying WD40 or equivalent spray lube in it ? Sometime 20+ years of weather can cause the brass tumblers to seize in the cylinder housing. Or, you mean the lock body, not the key cylinder ?
1992 Trans Am
May 10, 2023 07:19 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
