Battery Tray Replacement
Old Jun 18, 2014 | 11:19 PM
TheCardinal's Avatar
So guys I have been working on the Battery Tray it was rusted out and in bad condition, I have noticed this happens a lot on 3rd Gens. I ordered the new tray from Hawks Third Gen and decided I would put it in myself.
Original Battery Tray:
After grinding:
After Welding:
The Rest of this will be in the next posting
Old Jun 18, 2014 | 11:22 PM
Re: Battery Tray Replacement
After Sealer:
After Primer:
Finished Product:
It was still drying in this last picture will post another after it is finished drying.
Also, the front lip was rusted out so I created a piece to tie it into the core support just for giggles even though its in there very very solidly without it. My dad stood on it at 193lbs and its solid. HaHa
If you guy want anymore details drop a reply or wanna comment post.
Old Jun 19, 2014 | 07:15 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
It looks good, But since you had it rusted though why not just get a 4th gen battery tray that has the coolant bottle under it?
Old Jun 19, 2014 | 08:23 AM
First off thank you.
Dont, know much about that setup but, I wanted to keep the rigidity at the front of the inner wheel well plus keep it as stock looking as possible when you pop the hood. Realistically I would have had a bunch of holes I would have had to weld up after removal anyhow (or cutting/grinding) from the original tray so, it was no bother to take it out cleanly and do it right.
I plan on also trying to find a plastic tray just for added longevity to sit under the battery from some donor just incase of future leakage from the battery.
Old Jun 19, 2014 | 08:46 AM
Joe Tag's Avatar
You went a little excessive with the welding if you wanted to keep a stock appearance. Should have just drilled holes where the spots were and spot welded it. Anyone with some knowledge of these cars would take one look and know it was replaced.
Old Jun 19, 2014 | 09:49 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Battery tray is part of the inner fender support...
Old Jun 19, 2014 | 01:34 PM
Joe, I think you mean plug weld but ok. As far as being able to see it, Once the battery is in you only see a little bit of the front area below coolant jug.
Oh, and it sure beats the heck out of a piece of cookie sheet the previous owner put over the original rusted tray.
DJP, yes I know that.
Derick15
Sep 17, 2016 05:28 PM
justin57
Aug 20, 2015 07:05 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
