time to do the door hinges
Old Jun 19, 2014 | 12:07 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
its time to rebuild the door hinges on my 86. how big of a PITA is this job?i will be doing it by my self,unfortunately. any tips or tricks reccomended? also does anyone know where to buy the spring installation tool?
Old Jun 19, 2014 | 12:33 PM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Re: time to do the door hinges
some say its a PITA, some say its not so bad
its going to depend on how you view working on cars
the job is much easier if you build a support frame that will hold the door, and mount it on a jack to hold the weight of the door and place it where you need it
here is the tool, and its from one of our trusted vendors!
http://www.top-downsolutions.com/too...or-spring-tool
Old Jun 19, 2014 | 09:04 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Did a set on an 85 iroc a couple months ago..the spring compressor tool you can pick up at harbor freight for $4..
Old Jun 19, 2014 | 10:06 PM
TheExaminer's Avatar
Car: 92 Formula WS6, T-top
Engine: 5.7L T.P.I.
Axle/Gears: Limited slip, 3.23 10 bolt
Harbor Freight has one for pretty cheap. Can't remember what I paid for mine, but it was less than $10 I'm pretty sure. The hardest part about hinges for my 4th gen Camaro was getting the pin out. I don't have air tools so I had a buddy heat it, put a vice grips on it and use an air chisel to pop it out. It can be tough to get it out with regular tools. Of course, my 4th gen hinges were bolted in on both sides, which was both a blessing and curse. They were easy to get out, but it made for more possible adjustments when putting them back in. So don't forget to mark where they were before you take them out!
Old Jun 23, 2014 | 10:17 PM
SSgtRS's Avatar
Car: 92 Camaro RS
Engine: 3.1 V6, future LS1
Axle/Gears: 10 Bolt 3.23
Check out this website for some good info on 3rd gen f-body hinge repair:
http://www.andyz28.com/3rdGen/installation.html
Old Jul 7, 2014 | 10:08 PM
redfivexw's Avatar
I just did them on my 88 ta. Took the doors off the car, ground off the upper hinge bolts and installed new, installed lower hinge bolt, put back on car. Used a jack, a 10mm gear wrench box a 15mm socket for bolts. had to have someone position door while I installed the top rear bolt, otherwise alone.
Old Aug 3, 2014 | 03:59 PM
FXmanDan's Avatar
Car: Pontiac Firebird Formula / Trans Am
Engine: 5 Litre V8
Transmission: 700 R4
To support the door (when the hinge is removed) an old style step ladder is idea to put over the door then put a strap or rope around the door to suspend it from the step ladder. Pad the door with a cloth or something so it does not chaffe the paint.
Old Aug 3, 2014 | 04:11 PM
Engine: 5.7L T.P.I.
Interesting idea. Will have to look into that......
Old Aug 3, 2014 | 05:31 PM
FXmanDan's Avatar
Engine: 5 Litre V8
I think the worst part of the job is grinding the rivits out of the top hinge. But then I only had a little multi tool thing that was wanting to burn out. The ladder idea makes it a lot easier tho. Using a jack is probably ok but at least if its securely suspended from the step ladder it cant fall. It could fall off of a jack and be damaged.
Old Aug 4, 2014 | 10:38 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Make sure you mark the current hinge locations for re-installation.
Old Aug 6, 2014 | 12:07 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
I parked my car under a beam that runs the length of my garage. Then strung the door up with ratchet straps (under the door and over the beam). Then put a jack with a block of wood and a towel under the door. The straps were pretty much just to keep the door from falling off the floor jack. I only moved the door a few inches away from the car to work on the hinges..then slowly moved it back into place when I was done. Would have been easier with a door support frame or a helper...but I made due with what I had available.
Old Aug 8, 2014 | 12:41 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
it is easier to grind off the heads of the old upper pin if you remove the large triangular shaped chunk of rubber that is at the top of the door weatherstrip. There is one hidden screw that attaches it to the door. To remove the screw you have to remove the inner door trim panel. The "lazy" way would be to just break off the plastic tab from that triangular shaped piece, then reglue it in place afterward. I've never done it this way, nor do I recommend it. Removing the inner door trim panel is a bit of a PITA until you learn the tricks to it.
Once you have all the attachments free (door handle door lock, ect. Then pop all the plastic christmas tree fasteners free from the perimiter. Now slightly pull the panel out from the door while lifting it, then shove the door trim panel to the front or back of the door. This will release the top clips from their attachments. It is much easier to install than remove.
I sell the door hinrge repair parts and the tools that make the job easier on my web site.
Good luck.
Lon
Old Aug 8, 2014 | 05:40 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I used the transmission hoist to do the job.
Masking tape to protect the body from scratches.
Alignment marks, like already pointed out.
A 13mm ratchet wrench made the job a lot easier.
Attached Thumbnails time to do the door hinges-door-hinges-transmission-hoist.jpg   time to do the door hinges-protecting-body.jpg   time to do the door hinges-alignment-marks.jpg
Old Aug 8, 2014 | 05:49 PM
thomas1976's Avatar
Car: 91 Trans am
With my new oscillating cutting tool it took no longer than 2 minutes for each pin, without removing any weatherstripping. The down side is I needed 3 blades, each blade was only good enough to cut 1 and a half pin.
For the door hinge roller pin
https://www.thirdgen.org/forums/post...88-post30.html
Write ups
http://www.superchevy.com/how-to/060...-chevy-camaro/
http://andyz28.com/3rdGen/installation.html
Parts
http://www.top-downsolutions.com/Bod...and-roller-kit
http://www.top-downsolutions.com/Bod...ir-kit-(deluxe)
Attached Thumbnails time to do the door hinges-new-cutting-tool.jpg   time to do the door hinges-door-ready-install.jpg
Old Dec 26, 2015 | 09:29 AM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
[QUOTE=thomas1976;5803105]With my new oscillating cutting tool it took no longer than 2 minutes for each pin, without removing any weatherstripping. The down side is I needed 3 blades, each blade was only good enough to cut 1 and a half pin.
Hello,
Im about to do this repair, and i have one of these tools, a Dremel MM40.
Would it be possible to cut the pins without removing the door? The weatherstrip is not the best, so some damage to it is not a big concern.
I have the other kind of machine too, for the cutting discs, but this seems more efficient...
Old Dec 26, 2015 | 01:32 PM
thomas1976's Avatar
Car: 91 Trans am
Originally Posted by HasseO
Hello,
I don't think so, but I would have to look at it again, I remember it being a tight spot, particularly the lower one.
Old Dec 26, 2015 | 04:19 PM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
Hi,
Thanks. I you could I would be very grateful. My car is 40 miles)70km) away from here and I would like to be prepared and bring all the right tools.
I read up on this from several posts here, but would prefer not to remove it completely. The lower pin has to be cut too?
regards,
Hasse
Old Dec 27, 2015 | 02:14 PM
thomas1976's Avatar
Car: 91 Trans am
There is no space to work, door has to come off.
The pin on the bottom hinge is simple to remove, though the door has to come off for that one too.
Pic of the lower pin of the top hinge
Old Dec 27, 2015 | 02:55 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
I need to do my doors soon
Old Dec 27, 2015 | 03:49 PM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
Thanks Thomas, for taking the time.
The part I dislike the most is actually removing the inner panels...
Those plastic clips and things are so prone to braking and the door panel too.
But best do do it properly.
regards,
Hasse
Old Feb 20, 2019 | 03:54 PM
MobileHomie's Avatar
Car: '87 IROCZ
Engine: 414 Iron Block SBC
Transmission: T-350 w/brake
Axle/Gears: Moser 9" 4.30:1
I am sorry for bumping this old thread.
I bought a door hinge and bushing kit from Hawk Motorsport hawkmotorsports.com/bushing-pin-camaro-firebird-82-92-greaseable-upper-door-hinge-bushing-and-lower-pin-kit/
They listed this for a tutorial http://andyz28.com/3rdGen/installation.html
and the link is broken or the site is gone
Any help would be appreciated.
Biggest question is do I have to remove the fender?
Old Feb 20, 2019 | 05:26 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
The Grease-able pins are made by (or exact copies of) http://www.top-downsolutions.com/doo...)?search=hinge reach out to him, the owner's name is Lon.
Or call Hawks they sold it make them support it.
FWIW I did mine with my fenders off the car... it is super easy to do just takes time cutting and punching out the old pins.
Old Feb 20, 2019 | 05:39 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I did mine fenders on.To support the door. I took three 2x4s and nailed them together to make a u shaped cradle. I bolted on a socket on the bottom so it would fit perfectly into a floor jack.
Old Mar 10, 2019 | 06:49 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
Fenders on, if you have a buddy it's a big help, did mine myself almost exactly like Tuned Performance...
Old Mar 10, 2019 | 06:53 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
The only reason I did mine fenders off was I had them off for painting the engine bay. Otherwise I would not pull fenders just to do the pins.
One note I bent one of the light switches in the door jam, so if you do it fenders off pull those switches first.
Old Jun 12, 2021 | 05:09 AM
West305's Avatar
Car: 1990 Firebird
Engine: 305 carb
Transmission: 5 speed manual
A little trick I came up with was to cut a slot in the end of the lower front bolt. The one that’s hard to get to with fender on. I used a 1/4 socket and stubby ratchet to unbolt it. When you put it back in you can simply push the bolt into the hole with your finger and use an electricians screwdriver to wind it in from the inside until you need to tighten it with a socket.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Apr 9, 2016 10:20 PM
BlackTopKing
Aug 19, 2015 12:13 PM
