Quick question about painting headlight buckets
Old Jun 25, 2014 | 10:30 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
When painting the headlight buckets, should I mask first and then scuff the paint, or scuff the paint first? If you scuff first, how do you keep from accidentally scuffing the paint outside the headlight bucket? If you mask first, does the scuffing damage the masking tape?
Old Jun 26, 2014 | 12:37 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Quick question about painting headlight buckets
I watched as my painter used tape whenever he wanted a straight or curved line.
The man was AMAZING to watch. A true Professional .
Old Jun 26, 2014 | 01:12 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
ya runnin short on tape?
can't just as more tape after scuffin as needed?
Old Jun 26, 2014 | 07:11 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Tape, then scuff and then retape
Old Jun 26, 2014 | 04:37 PM
RSFreak's Avatar
Thanks! That's what I needed to know.
Old Jun 26, 2014 | 06:04 PM
Joe Tag's Avatar
Or.... you can mask off then plastidip them. Finally got up the ambition to do mine the other day. $7 and a roll of tape. Mess up? peel it and redo. Use at least two heavy coats and remove masking before completely dry.
P.S. If you want a good clean line around the curves, use pinstripe (vinyl in rolls) around the edge first, then mask up to it with regular tape.
Old Jun 26, 2014 | 06:11 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
x2 on the plasti-dip idea.
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
