Wheel center caps
Old Jul 19, 2014 | 05:10 PM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Wheel center caps
Hi,
I have an 82 Firebird. I restored a while back. The wheels I got with it are not original. They are from an 84 upwards car I think. These are quite common on the Firebirds as far as I am aware. I have seen pictures of these wheels with center caps. The question I have is since my car is 1982 with 82 back axle and front wheel hubs can wheel center caps be put on. The best thing is to look at another car but there are only a handful of Thirdgens here that I don't have anything to compare to. I have attached two pictures of front wheel and back.
Anyone help.
Thanks.
Attached Thumbnails Wheel center caps-img_20140716_193603.jpg   Wheel center caps-img_20140716_193633.jpg
Old Jul 20, 2014 | 11:12 PM
jez3941's Avatar
Car: 1984 Trans Am- L69, WS6, J65, W62
Engine: 350 .020 over
Transmission: auto 700R4
Axle/Gears: 4.11 Limited Slip
Re: Wheel center caps
yes that type of wheel was introduced in 84.
the axle and hub on your 82 is the same as later cars and you will have no problem with the center caps for those wheels being put on your car
Old Jul 20, 2014 | 11:53 PM
gholian's Avatar
Engine: 2.8 V6
Thanks for that, will get ordering.
Old Jul 22, 2014 | 04:16 PM
87350gtanj's Avatar
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
you should have no problems with center caps as stated rears are interchangeable 82-92 besides gear ratio and disc vs drum
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Scamo-2.8
May 20, 2016 07:01 PM
kah992
Aug 19, 2015 02:55 PM
