Factory tow points?
Old Jul 21, 2014 | 09:22 PM
joef2002's Avatar
Factory tow points?
Hey guys - I've been researching a ton on this place for recommended tie-down locations when loading the thirdgen onto an open trailer. I've decided to use the factory tow points to ratchet it down. I just want to make sure I'm looking at the right locations underneath the car:
Here's what I think is the tow point the front driver's side:
And here's a shot from the back driver's side:
Do I have this right? Are those circled locations where the factory tow points are located? Thank you!
Old Jul 21, 2014 | 10:11 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Factory tow points?
That's what I used when I towed my 'Birds home when they die in the city.
Old Jul 21, 2014 | 10:23 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Can ya ratchet strap the tires? Just another option.
Old Jul 21, 2014 | 10:25 PM
joef2002's Avatar
I wanted to, but can't. The trailer connection points are underneath the car...no where near the tires.
Old Jul 21, 2014 | 10:27 PM
red rock's Avatar
Car: 1987 iroc
Here are some ideas; https://www.google.com/search?q=tire...w=1280&bih=685
Old Jul 22, 2014 | 08:21 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Those are the points to use. I don't use wheel straps on my hauler, allows the body to bounce around. Best to keep everything stable. For the front, don't apply much side load , the tabs can bend. Yours looks clean, but we should be aware many third gens are too rusty to use frame points on a hauler. I strapped down a 91 that was so rusty, the tie down strap pulled the rear frame rail right off!
Make sure you are using straps with enough "working load" rating.
Old Jul 22, 2014 | 09:20 AM
joef2002's Avatar
Thanks guys. I appreciate the confirmation. Yeah I just purchased 4 ratcheting tie-downs. They are 2" wide and rated for a 10,000 lb breaking point with a working load limit of 3333 lbs. Hopefully more than enough for my needs.
Old Jul 22, 2014 | 01:20 PM
87350gtanj's Avatar
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
Yup looks good you can also can down around rear axle tube if necessary.
Old Jul 22, 2014 | 05:35 PM
stealtht/a's Avatar
Yup that's what I use. Watch out for the ratchet hitting the front bumper and air deflectors.
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Ranbo108
Sep 9, 2015 12:20 PM
scottmoyer
Sep 7, 2015 07:06 PM
TBRays98
Sep 6, 2015 05:05 PM
SlowAZ28
Sep 2, 2015 05:19 AM
