The same.... but not the same
Old Jul 26, 2014 | 12:30 AM
wildstar's Avatar
Car: 1984 L69 Trans Am
I'm installing '83 front GFX on an '84 TA with a brand new bumper cover. Things aren't quite lining up. The GFX has a flange that is supposed to be sandwiched between the bumper cover and front of the quarter panel. There is a hole in the flange where a bolt passes through, to secure all three pieces together. But the flange creates a gap between the quarter panel and bumper cover as seen in this link. Do you think I should just remove the flange with a Dremel, or am I missing something?
http://i1209.photobucket.com/albums/.../IMG_08961.jpg
Here's a shot of the flange I'm talking about.
http://i1209.photobucket.com/albums/.../IMG_08971.jpg
Old Jul 26, 2014 | 12:38 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: The same.... but not the same
Perhaps the flange fits on the other side of the bumper cover and not between it and the quarter?
Old Jul 26, 2014 | 01:05 AM
wildstar's Avatar
I just re-checked it but the bumper cover wraps around, preventing the flange from being in front. Maybe if I tighten the crap out of those through-bolts, it will close the gap?
Old Jul 26, 2014 | 12:35 PM
wildstar's Avatar
Well I've tightened and tightened and there are still gaps on both sides.
Old Jul 30, 2014 | 08:43 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
maybe if you found a assembly manual you could be sure to get it right. its what I did to rebuild the front on my 86.
Old Jul 30, 2014 | 08:53 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
IIRC, since it's been a while since I've seen the 84 I pulled a fender and the doors off of, that "flange" goes between the bottom of the fender bolt bracket (the thing with bolts in it) and the fender itself. Maybe not, but it obviously has to go either behind the fender metal or behind the bumper cover but not between the 2.
RedRokkit
Carburetors
Oct 29, 2013 07:21 PM
806camaro
Aug 18, 2013 12:38 PM
TPI TERR
Brakes
Oct 27, 2010 12:36 PM
1988TransAm22s
Jun 28, 2010 08:54 AM
ttoplover
Exterior Parts Wanted
16
Oct 28, 2009 09:44 AM
