side view mirror glass shaking
Old Aug 25, 2014 | 09:14 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
Hey guys,
So last week i was driving and heard something shaking and found the glass portion of my driver's side view mirror was bouncing around. not the housing, just the glass. the passenger side doesn't shake around. Is there a way to make it stop? I thought it disconnected from something inside so i tried to push it inward but still loose. I already searched with no results.
Thanks.
Old Aug 26, 2014 | 06:46 AM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Re: side view mirror glass shaking
If it's the same as my brother's '84 Corvette, the mirror is held by a rather flimsy little "cross" kept in place by flimsier notches, if one of them is broken, the mirror becomes loose...
Old Aug 26, 2014 | 07:06 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
My 91 has screws that hold the glass in place behind the mirror. You'll have to move the mirror around to it's limits to see them. They are hiding in behind the mirror in the pod. But you should be able to slip a philips screwdriver in there to get at them. Cover your screwdriver shaft with tape or something that will keep it from scratching the paint on your mirror pod.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
aaron7
Aug 26, 2015 09:45 AM
BrianI
Aug 9, 2015 11:52 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
