headlight doors
Old Oct 13, 2014 | 01:07 PM
ronchic's Avatar
Car: 1986 firebird
Engine: 305 v8
Transmission: auto
Axle/Gears: 2.73 ?
headlight doors
i,m new to pontiac and firebirds . i have a 86 that i,m restoring . the headlights having been working great , now all of sudden the right headlight will not go down. left side worked fine . did get it closed manually . any help would be appreciated , thankyou ron
Old Oct 14, 2014 | 07:59 AM
bryan623's Avatar
Car: 89 GTA
Engine: 5.7 TPI
Re: headlight doors
There's a few things you can try. First put the lights up. If one comes up try getting out with them still on and tug lightly on the light that will not come up. If it does, then it could be the motor for that light is going. It also could be a couple of teeth have became so worn down or have broken off completely on the gear and it won't engage or the motor itself is shot. Also it could be your headlight control module is bad or on its way out as well.
I am pretty sure your control module is in the same place as mine (different year and car), but it should be in the same place I believe. Try lightly tapping on it or wiggling the connections. If the light comes up it means the solder joints could be worn or completely broken off (that's what I was told at least).
Edit: Sorry I see that you are having trouble with it going down. Though it could be the same problem. A few teeth broken off or worn out at the the end when the light is in its up position. Also it still could be the headlight control module as well.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Buggy Disaster
Sep 17, 2015 05:12 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
