Best body filler for engine bay smoothing
Old Dec 8, 2014 | 06:49 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I am in the process of welding in panels that cover both battery trays, fender holes, and smooth out the passenger side firewall. I also removed all the mounting holes on both inner wheel wells.
Needless to say I am not a professional body guy so I am looking for advice about what is the best body filler to use when you know you will have some places be a bit thick. I bought a DVD from Eastwood about how to paint your car. It was very helpful. The instructor says to make sure to buy nice filler so that it doesn't shrink. This seems like very sound advice.
Does anyone have any experience with good filler, or even bad filler so I know what to avoid?
Thanks.
Old Dec 9, 2014 | 08:30 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: Best body filler for engine bay smoothing
If you keep it less then a 1/8 thick then you should be fine using rage body filler if you need more then an 1/8 then I would use kitty hair first
Old Dec 10, 2014 | 11:58 AM
Engine: LS3
What is kitty hair, a fiber reinforced bondo? Shouldn't I be making sure that it is low shrinkage? I am just smoothing non-critical frame bumps and stuff like that. I don't think I will be going any thicker than 1/8", maybe in a very small strip hear and there, but I am not sure. I am currently at the stage when I am final welding all the panels in place. They are all cut and tacked. After that I will be grinding followed by the second round of welding, then a bit more grinding followed by the filler.
Old Dec 10, 2014 | 06:42 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Not saying it's the best, but it's what I've always used and works well:
Old Dec 11, 2014 | 09:11 PM
Engine: LQ4 ls 6.0
Then all you should need is a good filler I like Evercoat rage
Old Dec 22, 2014 | 11:48 PM
92GTA's Avatar
For sure, Evercoat Rage is awesome!
Old Dec 23, 2014 | 09:24 AM
87350gtanj's Avatar
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
regular rage or rage gold????
Old Dec 23, 2014 | 09:27 AM
92GTA's Avatar
I've never bought the just "Rage" plain version so I don't know. When you go to your local auto paint supplier/wholesaler, as them which would be best for the high heat of the engine bay. My local place is pretty knowledgeable but I've also only ever done exterior work with it.
Old Dec 23, 2014 | 09:32 AM
87350gtanj's Avatar
ok because theres rage,rage gold,rage ultra and rage extreme.i'd be looking for more exterior use myself
Old Dec 30, 2014 | 12:56 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Depending what you are wanting to hide, brazing with an oxy acetylene torch may be best. You can also mig or tig by the thick seams like the strut towers. I don't like using much of the body filler in the engine bay because I will accidentally hit fenderwells and firewalls with heavy tools or an engine / tranny when changing an engine and I don't want to worry about cracking a spot that needed 1/8-1/4" of Bondo type filler.
Old Nov 20, 2016 | 07:16 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Posting again as a follow up. I started out using the standard Evercoat Lite Weight filler on my engine bay and found it to be extremely hard sanding and it took longer to fully dry. I switched to Evercoat Rage Ultra and absolutely love it, it was much easier to sand. It is about twice as much but worth every penny. I tried to use as little filler as possible so I always opted to build up the area of a seam with a weld rather than slapping on some filler. There are a couple threads where the guys really slathered on the filler around the firewall and strut tower caps, don't do that. The strut towers are known to move and can potentially cause cracks in the filler.
Old Nov 21, 2016 | 12:08 PM
03glide's Avatar
Car: 84 Z28
Transmission: auto
SMOOOOOOOOTH!
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
