How to close window?
Old Dec 15, 2014 | 08:59 PM
blktransam's Avatar
Car: 1988 and 1987 Trans Ams
I recently got a parts car that has a window that isn't fully rolled up. The car is not hooked up to a power source, is there any way to get power to the window motor, so I can roll it up? It's raining and my interior is getting soaked!
Old Dec 15, 2014 | 10:36 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: How to close window?
Assuming all the wiring is intact, hook up a pair of jumper cables to the battery terminals on another car and to the battery wires in the bird. You should be able to use the window switch to roll them up then. DO NOT let the cables touch each other or any metal in the bird. Not the safest way to do it, but certainly the quickest.
Old Dec 16, 2014 | 09:32 AM
blktransam's Avatar
I'm not sure the wiring is intact.... I will try that though.
Old Dec 16, 2014 | 12:51 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Take the door panel off, unplug the motor, apply 12 volts to motor connection. If the window goes down, switch wires. When window is up, remove power.
Old Dec 16, 2014 | 01:35 PM
crzymike's Avatar
You can use your battery from a cordless drill for the power source. Then take off door panel and apply two wires to window motor and drill battery. This is how I test the motors in the junkyard before i remove them.
Old Dec 16, 2014 | 04:33 PM
blktransam's Avatar
That's brilliant! Thanks guys!
Fronzizzle
Sep 8, 2015 12:10 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
scottmoyer
Sep 7, 2015 07:06 PM
SG91camaro
Sep 5, 2015 10:27 PM
