89 Convertible trunk lid
Old Dec 22, 2014 | 02:21 PM
dougtallman724's Avatar
Bought an 89 vert to play with not too long ago. it needs plenty of tlc. Right now the trunk lid refuses to latch closed. Everything looks to be working, but without latching. Which parts should i suspect and replace? Help!
Old Dec 23, 2014 | 04:39 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: 89 Convertible trunk lid
Follow the Tech Article I wrote that is posted on TGO under "General Repair" section. First, have you tried pressing on the striker-sensing switch? If you press it the unit should power down, then release the switch when the unit reaches the end of the down cycle and you hear the "CLICK". If that doesn't work, then check that you have power at the red/white stripe wire that is plugged into the blue wire. Next, call me and I'll give you instructions on how to test the reversing switch.
Lon Salgren
Old Dec 23, 2014 | 07:18 PM
Hey! Thank you for the info. i will probably get to try your suggestion after the holidays now. i will let you know or give ou a call if it doesnt. Enjoy your holiday season!
84LsxZ28
May 17, 2020 02:21 PM
armybyrd
Dec 5, 2015 09:22 AM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
sylentnite
Sep 9, 2015 02:55 PM
SG91camaro
Sep 5, 2015 10:27 PM
