Rate my undercarriage?
Car: 1985 TA http://bit.ly/1EadkbO
Engine: 5.0 V8 LG4 BBL
Transmission: 5 Speed Manual
Hey Guys,
My cars undercarriage seems to be the worst part, its an 85 Trans Am.
https://www.flickr.com/photos/113572...7651553173808/
This is my first Trans Am, and i haven't owned a car with this kind of problem since the 90's, so i forget what to look for.
What do you think?
Anything serious you can see under there?
Its at a mechanics right now, so i am sure he'll let me know, but i'd love your opinions.
Car: 88GTA
Engine: 5.7TPI
Re: Rate my undercarriage?
No Cat??
OTT, don't look too bad. Exhaust system and maybe a cleanup, Oil Pan, Rear Main Seal, Timing Cover Gaskets...
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
I don't see anything wrong with the undercarriage. Take a wire brush to get some of the surface rust off, then get some undercoating on it. Looks pretty great floorpan wise, honestly. The thing I would do is redo the exhaust, it's looking kind of meh.
Thanks for the replies guys - yep no CAT - its a WA car, i'm getting CAT installed as i am in CA.
Glad to be part of the 3rd Gen community :-)
It would be bad for a CA car but being where you got it from, looks fine. I've seen WAY WAY worse over the years on here from people who's cars have lived in the rust belt.
Get all that surface rust off there properly instead of just painting over it, and get it sealed so it doesn't get worse. Even in CA, once rust starts, it will still keep going.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Looks 1000% better than anything around here. Clean the scale and hit it with POR15 or Rust bullet.
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Around here we douse it with diesel then power wash it with hot water - cleans just about everything off but expect to get dirty.
http://www.hotrod.com/how-to/paint-b...removal-guide/
Might try it though :-)
Car: 84 Z28
Engine: 383 Stroker
Yeah, I was going to say, Lookslike a down south kind of rust. That is nothing. come up to MN and I will show you what rust/rot looks like!! lol. not too bad!
Engine: LB9
That actually works? I was thinking more something like they have here
For the rust use the Evapo rust & keep it moist - it DOES work.
Ditto. I used Evaporust on the frame of my 56 Corvette and it was freakin awesome! I used it for a bunch of other parts well!
Thanks for the info guys, I'm wondering if i need to go with a gel solution or something though, its going to be really hard to keep the undercarriage wet.
Axle/Gears: 10 Bolt 2.73 Open
I've used Metal Rescue...same sort of product I think. But it's a liquid. Outside of a rotisserie, how would you keep a product like this wet for a 24hr. period, upside down, on the underside of a floor?
This customer used a spray bottle, and lots of constant effort. But to do the whole underside of a car...that would be a quite a task.
http://www.evaporust.com/chassis.html
Exactly. If you look at the hot rod article there is one product that looks like a sticky gunk. That looks like what I need!
Engine: LB9
What was done with one of the low mileage GNX cars that was poorly stored and covered in surface rust underneath was the car was driven over one of those cheap inflatable pools that you can buy at Walmart and the pool was inflated. A grid of 1" pvc pipe drilled with small holes was placed underneath & the Evaporust was pumped through them with a cheap electric pump. The sprinkler system was set to hit every portion of the car underneath and left there for a week. When it came out and was cleaned off it looked like the day it left the line & got top dollar when it crossed the auction block a few months later!
This may be a more involved project than you want to get into but simply wrapping portions with soaked towels and cellophane should produce similar results without having to flip the car over.
LT1Formula
Oct 8, 2015 08:34 PM
