Front Lower Triangular Brace Right Side?
Old May 10, 2015 | 04:12 PM
GregLobb's Avatar
Under the Evap Cannister on the left side of the car there is a triangular brace supporting the panel is sits on. As I have dismantled most of the front end, I am a little lost with the right side.
Is there not the same brace supporting the battery panel on the right side?
Greg
Old May 10, 2015 | 04:32 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Re: Front Lower Triangular Brace Right Side?
Yup
Old May 10, 2015 | 07:18 PM
Wife'sCar's Avatar
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
That's not the same part he posted. I know exactly what you are talking about. I know for a fact there is one on the driver side.
Just checked, I do not have one on passenger side. I believe that brace is to strengthen the mounting of the steering box.
Old May 10, 2015 | 07:32 PM
Wife'sCar's Avatar
Engine: 5.0 Tbi
This is what you are looking at
Old May 10, 2015 | 09:51 PM
GregLobb's Avatar
Thanks Ted but WifesCar is referring to what I mean. So WifesCar does this part exist on the right hand side of the car under battery panel/shelf?
Old May 10, 2015 | 10:37 PM
GregLobb's Avatar
O I should asume the all Third Gens dont have this brace on the passenger side? I dont usually misplace parts or even bolts, so in all probability there wasnt one.
Would it be pushy to ask you for a picture of the under side of the passenger side for me.
Thanks Dude
Old May 10, 2015 | 10:45 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
My Camaro does not have the brace on the passenger side nor are there bolt holes for it either.
Old May 11, 2015 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following link discusses the brace in question at some length (as well as other braces that some cars have and some don't):
https://www.thirdgen.org/forums/susp...e-confuse.html
JamesC
Old May 11, 2015 | 06:58 AM
Wife'sCar's Avatar
Engine: 5.0 Tbi
Thanks Dude
I promise there is not one on my passenger side. There is nothing to take a picture of.
Old May 11, 2015 | 09:14 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
That is a battery tray support. It goes on whichever side the battery is on. Earlier cars had the battery on the pass side, tpi cars have it on the drivers, prob other engine variations.
If you have one on the side opposite the battery, it's because of an engine swap or wiring swap or someone thought it would be a good brace on the light side too.
Old May 11, 2015 | 09:30 AM
Wife'sCar's Avatar
Engine: 5.0 Tbi
It's a steering box brace. It goes on the driver side. I have never seen one on any car on the passenger side. My car had the original motor when I bought it and I know for a fact I never removed it when I put the new motor in. Every car I have ever seen it's on drivers side and its a pain cause it blocks one of the steering box bolts.
Old May 11, 2015 | 09:42 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Old May 11, 2015 | 10:27 AM
stealtht/a's Avatar
Doh! You guys are right! Sorry must have been thinking of sone other car. Went back and looked at my tear down pics and they are only on drivers side.
However, I think it was a piece of faulty engineering. It seems to me the only force this would brace against would be twisting of the frame rail, which seems to be very small consideration compared to the lateral force generated in the steering, which we know these didn't brace well enough against since they had to add the wonder bars.
If it does offer any significant bracing against the rail torquing, seems like it would be good to have one on pass side to.
I might add one to the pass side....
Old May 11, 2015 | 10:39 AM
Wife'sCar's Avatar
Engine: 5.0 Tbi
I don't believe there are any mount holes on the pass side, would be easy enought to fix. But I'm not sure it would make all that much difference.
Some engineer thought it was a good idea at the time.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Street Lethal
Aug 14, 2015 08:25 PM
NBrehm
Aug 5, 2015 07:57 PM
