Help! Need attachment info
Old Jun 18, 2015 | 10:50 PM
retro-roco's Avatar
Have an 88 formula, with no GFX. Removed the rear bumper cover and the plastic eggcrate absorber about two years ago. In spite of numerous pictures, manual research, etc. I can't remember how the absorber attaches to the metal crash bar. The holes are only 3/16 dia, and show no signs of being threaded. Presume I need either plastic rivets, or should they be metal pop rivets??
Thanks!
Old Jun 19, 2015 | 01:59 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Help! Need attachment info
85-90 used Rivits,the book doesn't say what size,it just says,Rivit,Energy ABS. so that would mean Plastic.
Old Jun 19, 2015 | 02:22 PM
retro-roco's Avatar
Ok, thanks. I'll have to see if I can find some 3/16 dia ABS rivets.
Old Jun 19, 2015 | 02:26 PM
mantaguy's Avatar
Engine: 5.0 EFI
Try this place.
http://www.clipsandfasteners.com/3_1...p_p/a13746.htm
Old Jun 19, 2015 | 03:05 PM
retro-roco's Avatar
Yep, I'd already tried them... The challenge is finding one with a long enough "grip" to go through both the absorber and the impact bar.
Old Jun 19, 2015 | 03:10 PM
retro-roco's Avatar
Actually finder in the rivet catalogs that most manufacturers ABS rivets are Aluminum Body/Steel mandrel (hence the ABS). Most plastic rivets I've found are Nylon, not ABS plastic. That should make it as easy as visiting my local hardware store.
wigmobile
Feb 26, 2025 02:56 PM
my86bird
Oct 23, 2015 12:20 PM
okfoz
Sep 22, 2015 03:37 PM
Saxondale
Exterior Parts Wanted
Sep 16, 2015 06:32 AM
MORREALE5
Sep 13, 2015 09:01 PM
