body/rust help
Old Jun 21, 2015 | 07:59 PM
92projectcamaro's Avatar
Car: 1989 rs coupe
Engine: 2.8 turbo build
Axle/Gears: 3.27 posi
body/rust help
so I have my 1992 Camaro I got a while back ive been fixing up now my questions are 1. my driver side floor pan is rusting up can I cut out the bad metal and just weld new sheet metal in. 2. my two rear wheel wells are rusting up what can I do to fix the damage?
Old Jun 22, 2015 | 05:26 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: body/rust help
Pictures would help this thread. No way to know for sure how badly rusted your drivers pan is. If its real bad you may want to either get a new one or a find a junkyard and cut the floor pan out of a junkyard car. Hope your good at welding as this gets pricy fast if you have someone else do it.
Old Jun 22, 2015 | 09:23 AM
Car: 1989 rs coupe
Re: body/rust help
I can do the welding lol.
Old Jun 22, 2015 | 12:09 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: body/rust help
Post some pics of the damage
Old Jun 22, 2015 | 12:10 PM
Car: 1989 rs coupe
Re: body/rust help
I will today
Old Jun 22, 2015 | 11:13 PM
Car: 1989 rs coupe
Re: body/rust help
There's the floor
Old Jun 23, 2015 | 07:31 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: body/rust help
You haven't seen the worst yet, wait till you pull the carpets out.
As I posted in your other thread, I think you bought a bucket of rust. I'm pretty sure I'd be junking that one. Seeing the foam someone stuffed in there doesn't make me feel any better about it.
Regardless of how you feel about restoring that body, next thing you need to do is remove the interior. You almost certainly have rot everywhere and you need to get a complete picture of how much work this car that has very little monetary value is going to cost you. Have you looked inside the windshield vent channel? I'll bet it's a mess.
Old Jun 23, 2015 | 07:34 AM
midias's Avatar
Re: body/rust help
That looks rough. If you really set on fixing it I would strip the interior, buy new floor pans so I could check and fix the frame rails.
Expandable foam is scary I use that on junk beater cars and nothing else.
Old Jun 23, 2015 | 11:49 AM
Car: 1989 rs coupe
Re: body/rust help
I vhecked the frame rails and the window channel actually is pretty clean I honestly think someone spilled a few drink in there over the years and it slowly ate the floor away and the only reason the foam is there was cuz the guy before me was just to lazy to repair anything he just spray that ****. The money value has nothing to do with it this car has a lot alot of sentimental value
Old Jun 23, 2015 | 11:50 AM
midias's Avatar
Re: body/rust help
In that case strip the entire car, brace the inside and put in new floor pans.
Old Jun 23, 2015 | 11:53 AM
Car: 1989 rs coupe
Re: body/rust help
And its only the driver side too the passenger side has about no rust
z28monster
Jan 25, 2004 11:51 AM
