Hood won't open on 91 Firebird, hood spring broke
Old Jul 26, 2015 | 04:27 AM
nhra-trans-am's Avatar
So after months on finishing up the swap on my Firebird and getting it registered, I went to drive the car and unfortunately dead battery.
I went to pop the hood to throw the charger on it but when pulling the release the hood didn't pop up. I thought the release cable broke, but after getting under the car, I saw that it was still functioning.
After prying the hood up a bit to get a better look I noticed the spring on the hood that "pops'' it up when the release is pulled had broken off.
Any suggestions on how to get this bad boy open. I've tried prying it up while pulling the release and pushing it up from the bottom to no avail. The hood shocks are still good, so I thought one of these options would work, but after many failed attempts, it just wont budge.
Anyone experience something similar and able to pop it open?
Old Jul 26, 2015 | 07:35 AM
snakeshooter's Avatar
Re: Hood won't open on 91 Firebird, hood spring broke
Have a buddy pull release cable while you first push down then try pulling up on hood. That should make it release. Are you sure the release is working as it should?
Old Jul 26, 2015 | 07:48 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Sounds like the latch needs oiled..
Old Jul 26, 2015 | 12:39 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Jack up the vehicle and remove the two bolts that secure the latch bar. Can only be seen and done from underneath. Did this at P-N-P one time to remove a hood with a broken latch. Good luck.
Old Jul 27, 2015 | 04:02 AM
I tried that as well. From what I saw the release cable was working. I will have to double check to be sure.
I had actually just oiled it two weekends ago. It was working well before the spring broke off
Thanks, I will have to try that. Looked like tight quarters, but that may be the only way at this point.
Old Jul 27, 2015 | 10:06 PM
TTOP350's Avatar
You should be able to push up on the bottom of the hood with a rubber tipped wood stick while someone pulls the latch to open it.
Old Jul 27, 2015 | 11:10 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
My first project on all the used 3rd gens I've bought was getting the hood open.
Old Aug 12, 2015 | 07:26 PM
a62belair's Avatar
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
Our Camaro had a similar issue. The fix was to push the hood release handle 'back in' to the panel. Somewhere in it's previous history, the return spring was weakened.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Jae992
Aug 27, 2015 09:07 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Randomtask2
Aug 13, 2015 01:57 AM
