Will 145mph speedo out of firebird work in 86 IROC????
Old Dec 19, 2001 | 11:01 AM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
There is one at my local yard I remeber seeing bout a month ago,will they interchange,I don't remember what year firebird it was though
Old Dec 19, 2001 | 11:15 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
No, for 2 reasons. First, camaro and firebird gauge clusters are completely different, the speedo will not fit. Second, your 86 has a cable driven speedo, whereas firebirds went to electric in 86. You could not get a cable driven speedo in a firebird that went above 85mph, so if you found a 140 speedo, it must be electronic. FYI: camaro's did not go to electric speedos until 91, when the entire gauge cluster was changed.
Old Dec 19, 2001 | 11:42 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Actually the Camaro dash changed in 90, not 91. Just splitting hairs.
Old Dec 19, 2001 | 01:45 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
bah... Hey I was suprprisingly close for someone who owns a firebird...
Old Dec 19, 2001 | 02:47 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Everything stated above is correct the firebird speedo probably would not work in a camaro. It MIGHT be possible to do a little research at the library figure out what you need & install the 140 speedo & the speed sensor into your 'maro. Its NOT impossible, but definately a challenge...
For sure you will need the speed sensor (from trans) Wires & the speedometer, then you will have to figure out a way to mount the speedo. Chances are you would need to at least make a custom made speedo face plate. Get some .060 plex for that, you would also have to make some sort of brackets & such inside your Instrument Panel (IP). There is a possibility that the Speedometer stuff might not actually fit into your IP. because of clearances.
Keep in mind this is all theory, & it might be possible if you do a little research & tinkering. I have NOT done this, but could see how it might work.
There is also a possibility that you would need the matching gear inside the trans, for the electronic sender unit.
Then again, it might be a bust & you waste $70 or so bucks on the firebird IP. Which you could sell on E-bay if in good condition.. .
If it worked out you could write a tech article how-to I imagine there would be several guys who would be interested in converting over their mechanical speedos to electronic.
John
Old Dec 19, 2001 | 06:01 PM
toosloz's Avatar
i am selling one....you got mail
Old Dec 19, 2001 | 06:54 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
just cough up like 50-100 bucks and get a 145mph iroc cluster. takes about 10 minutes to install
Old Dec 20, 2001 | 07:59 AM
okfoz's Avatar
But what kind of fun is that????
{mumbling to himself} just buy one made for your car and it will take only a couple of minuetes....
Just kidding....
John
Old May 26, 2004 | 01:34 PM
TTA1231's Avatar
Excuse me, are you selling a firebird 140 spedometer? If so, I am interested.
Old May 26, 2004 | 01:37 PM
Diabolical's Avatar
Engine: 305HO L69
omg back from the dead, this post is like 3 years old
Old May 26, 2004 | 02:26 PM
TTA1231's Avatar
OOPS! Sorry about that! I did a search for 'firebird 140 speedometer' and this is what came up. I kinda need one since my odometer broke.
Old May 27, 2004 | 08:10 AM
okfoz's Avatar
IF you just want the Odometer, ANY Firebird with the electronic Speedo from 1986-1992 will work, you can disassemble them and put it in. Just reset the new odometer to the correct mialage for your car.
John
Old May 27, 2004 | 09:28 AM
TTA1231's Avatar
John
Thanks for the info, I appreciate it.
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
Wade787b
Sep 29, 2015 01:15 PM
Irocohio
Aug 12, 2015 08:03 AM
mustangman65_79
Aug 11, 2015 03:17 PM
beachrodder
Aug 7, 2015 04:27 PM
