Hatch release wiring issues
Old Nov 17, 2015 | 07:54 AM
gnilson's Avatar
Car: 1990 T/A
Engine: 5.0 TPI
Axle/Gears: 373 posi
So I inherited a bit of a mess with the wiring for the electric release, but after sorting through the various plugs and broken wires, I got the latch to retract and pull the latch down. However, I could not get it to release. After releasing it with the key, I cannot get the latch to operate at all as it will not catch the hatch. Is it possible the switch itself is bad? I replaced the relay as well.
Any ideas would be appreciated.
TIA
Geoff
Old Nov 17, 2015 | 10:18 AM
gnilson's Avatar
Car: 1990 T/A
Engine: 5.0 TPI
Re: Hatch release wiring issues
After further contemplation, I realized there appears to be some kind of sensor that needs to make the connection. The PO had installed a replacement hatch and left all the interior cladding off in preparation for paint, I assume.
When the hatch is closed, does that complete the circuit telling the release mechanism that it is ok to do its thing?
Old Dec 16, 2015 | 05:23 AM
gnilson's Avatar
Car: 1990 T/A
Engine: 5.0 TPI
Ok, I have the hatch closing issues mostly figured out, but I still can't find the fuse and or relay for the remote release on the dash. I have no power to the switch so I have to assume it is one of those. I have looked under the dash in the passenger footwell as well as all the fuses in the fuse box.
Any body with experience on a '90 T/A or similar able to chime in?
TIA
Geoff
Old Dec 16, 2015 | 07:10 AM
B4C5.7's Avatar
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
I have a harness from a 1989 IROC for hatch pull down and taillights that is undamaged. Let me know if you think that that would help.
Old Dec 16, 2015 | 03:17 PM
gnilson's Avatar
Car: 1990 T/A
Engine: 5.0 TPI
Thanks for the offer, but I have power to the rear, I don't have power to the switch at the front. I am told they are on separate circuits.
dragonmas
Dec 26, 2015 08:49 AM
sleprock
Dec 2, 2015 04:54 PM
PetursGTA
Nov 16, 2015 05:10 PM
sgp0511
Nov 15, 2015 07:14 PM
