Door Rattle
Old Apr 2, 2016 | 09:07 PM
stegal's Avatar
Car: 1990 RS, 2002 Chev Silverado
Door Rattle
My Drivers side door rattles on rough roads. The hinge pins are tight. The door is hard to close with windows up. Any suggestions.
Old Apr 2, 2016 | 09:53 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: Door Rattle
The doors on these cars are quite heavy and tend to sag over time. You will probably have to re-adjust the hinges to get a better fit. Part of the issue is that since thirdgens don't have full frames the bodies tend to flex a lot and cause panel fitment issues especially if your car has t-tops. The best way to fix the issue is to put a set of subframe connectors on your car to make it more rigid and then adjust the hinges.
Old Apr 2, 2016 | 10:43 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: Door Rattle
Many many reasons from door handles, window adjustments, weather striping, inner rods etc...
Keep in mind with the window adjustments, to make sure that the inner pads aren't worn trough or it will permanently scratch the glass.
https://www.thirdgen.org/forums/body...servation.html
1fastrock
May 25, 2017 10:44 AM
AW119 Pilot
Pacific Northwest Region
Apr 15, 2016 11:03 PM
evan555222
Apr 3, 2016 07:10 PM
TheJoeY88
Apr 1, 2016 03:08 PM
Bluestreek
Apr 1, 2016 02:03 PM
