Relocating radiator overflow in 87 Firebird
Car: 1987 Firebird Formula
Engine: Carbureted - 305
Hi,
I have the 305 carb engine and want to set up a dual snorkel. I am in the process of building one now. I would like to move the radiator overflow tank to the drivers side and get rid of the windshield washer tank. I will never use it.
I have searched this site and did find some into a while ago on using a different year overflow that will fit on the drivers side, but I cannot find that info now.
Does anyone have any info on what tank I can use.?
Thanks,
Louis
Thanks,
Louis
Re: Relocating radiator overflow in 87 Firebird
To my knowledge, there was never a thirdgen with the overflow on the drivers side. That being said, pretty much ANY overflow will physically function, so long as you're able to make it fit. I bought an aluminum tank off ebay and tucked right in front the radiator/support. You can't see it unless you look for it, and I might've lost a few square inches of radiator space.
Hi, that's a great idea. What is the capacity of the tank you used. I think the original tank is about one gallon.
thanks,
Louis
It was much smaller. Probably a liter maybe? -just a guess. It looks exactly like this...although size is hard to tell from the screen shot.
http://www.ebay.com/itm/High-Perform...hUglgM&vxp=mtr
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You can also use stock fourth gen overflow tanks. A couple good writeups on here. Not hard to do and really cheap. They can go under the battery tray or in front of the radiator.
I have one like this on a restored jeep. It works out just fine. Thanks for the reminder.
Louis
maroe624
Apr 12, 2016 01:45 PM
