1985 camaro headlight wiring harness
I purchased these head lights awhile back and they never have really been wired correctly they just had the factory harness cut off and hardwired to the new headlights. I have the chrome diamond cut headlights with the h4 bulbs but whenever I put on the high beams they flicker and I just got my car out for the first time this season and one headlight doesn't work. Any suggestions? Buy the proper harness?
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: 1985 camaro headlight wiring harness
H4 conversions require higher current needs than the stock wiring can provide and result in many problems. You can build or purchase a relay harness that will work well in this case. Here's an article from the howtos section that outlines the whole process. I think Summit or various other vendors offer pre-made harnesses, you'll have to look. Here ya go
https://www.thirdgen.org/headlightupgrade/
Henry
Henry
hiller1162
Jul 4, 2016 09:20 PM
