side work
Old Oct 16, 2016 | 04:09 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
side work
just got finished putting epoxy over acid treated metal. I stripped it with https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
then I went over it with 80 grit on a da to remove anything that was left. then I took it outside and sprayed it with a mixture of water and milkstone remover( phosphoric acid) and used a 4 1/2 in grinder with a wire wheel cup brush to work it into the metal.
then I wet the acid one more time with more acid and continued to rinse it off with water. next time I will wash it with dawn soap and a scotch brite because when I was wiping it off there was milkstone residue.
then I dried it off and blew it off really good and used heat guns to get it really dry. I went over it with 80 grit and a da again and wiped it down with wax and grease remover and shot it with spi epoxy 30 min later.
when you are wire wheeling the acid I was wearing a rain suit and full face mask and boots. make sure you do this in colder weather.
Attached Thumbnails side work-m_dscn0037.jpg   side work-m_dscn0036.jpg   side work-m_dscn0038.jpg
Faolan
Sep 11, 2016 03:29 PM
db057
Sep 5, 2016 07:09 AM
blacksunshine'91
Convertibles
Aug 28, 2016 08:57 PM
dale3in98
Exterior Parts Wanted
Aug 24, 2016 04:08 PM
MikeT 88IROC350
Wheels and Tires
Aug 17, 2016 08:06 PM
