Hood gap problem
Old Apr 24, 2017 | 07:04 PM
millerliteliker's Avatar
Hood gap problem
I have a 1982 Z28 with 3,000 original miles. It has a had a re-paint.
My problem is the hood. The driver's side front corner sits quite a bit above the front of the fender (see picture below). The bumper is all the way down. You can push down on the hood and it will close the gap, but it comes right back up.
Any ideas on how to adjust this out? I did order a new hood latch, but I can't really see how this would be the problem. The gap is good along the front of the hood at the top forward line.
The other side of the hood fits much better, although it sits a little high, but not like the driver's side.
I realize that the gaps on these cars new was not great, but this is obviously out of tolerances.
Old Apr 24, 2017 | 11:37 PM
Drew's Avatar
Re: Hood gap problem
Everything is adjustable. The hood latch has a ton of adjustment. Those little rubber bumpers on the top of the radiator support, they're adjustable. The rubber bumpers under the back of the hood hinges, adjustable. There's another rubber bumper in the middle of the hood at the back behind the cowl weatherstrip. The hood latch support is adjustable too.
Start making small adjustments until it fits better.
Old Apr 25, 2017 | 06:20 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
How's your door gap?
Old Apr 25, 2017 | 08:39 AM
door gap is good. The hood at the back (windshield) gap is good too.
What I don't understand is what is holding the front corner of the hood up, since it is not sitting on they bumpers. I guess maybe the hinges?
Old Apr 25, 2017 | 11:56 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
is that a fiberglass hood?
being as it was repainted, i wonder if its possible that it warped from heat in the paint curing process?
did it fit good before paint?
Old Apr 26, 2017 | 07:25 AM
thanks to all of the advice - I did get it adjusted correctly and now it fits.
thanks!!
Old Apr 26, 2017 | 09:34 AM
Drew's Avatar
Which adjustment was the key? For future reference.
Old Apr 26, 2017 | 09:41 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Please share HOW exactly you fixed the gap, so others can use that knowledge in the future.
Old Apr 26, 2017 | 11:54 AM
djwyman's Avatar
Car: 91 Camaro RS
Engine: TBI 305
This is some good info mine has some gap problems too.
Old Apr 29, 2017 | 07:15 PM
It really comes down to the hinges - my hood was in a "sprung" position because of a bad adjustment at the hinges. It is not easy to explain what I did - just alot of adjustment needed. But the hood was definitely sprung. It shuts alot easier now too. If your hood is hard to close AND it has a big gap - it is in a bind.
