Driver side exterior door handle doesn't work.
Old Feb 28, 2018 | 07:47 PM
1985CamaroSport's Avatar
The driver side exterior door handle does not open the door and has no tension on it, the door will open from the inside handle just fine and lock. Has anyone repaired this issue before? Thanks.
Old Mar 1, 2018 | 03:03 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Driver side exterior door handle doesn't work.
You'll need to get the door panel off to find out what exactly has broken. Could be the handle itself, could be the rod that it connects to, or could just be a plastic clip that holds the rod in place.
Old Mar 1, 2018 | 06:49 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
I would bet that the exterior handle is broke and needs replaced. It's a pretty common thing to happen and the handle is around $15 new.
scarecrow23
Interior Parts Wanted
Sep 13, 2013 11:58 PM
Spd-Kilz
Aug 1, 2012 09:22 AM
Red_Bully
May 19, 2007 01:11 PM
Aviator857
Nov 8, 2005 10:22 PM
simpdogg11
Jan 2, 2001 03:01 PM
