new hood will not close??
Old Mar 1, 2018 | 04:08 PM
MORREALE5's Avatar
Car: 1987 IROC Z
Engine: L31 VORTEC
hello, i just installed new hood(steel),new hood hinges.my hood lines up and locks but the back of the hood by the cowl will not shut on both side unless i push it down? i know about the hinge stops and i think there adjusted propery because when i push it down it lines up good.rear of hood will not go down unless i push it down.do you think it could be bad lift struts?i tried spraying some wd40 on new hinges but no luck??any help would be great thanks.matt
Old Mar 1, 2018 | 04:09 PM
MORREALE5's Avatar
Car: 1987 IROC Z
Engine: L31 VORTEC
Re: new hood will not close??
sorry 1987 z28 if that helps
Old Mar 1, 2018 | 10:42 PM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
Usually that is caused by worn hinges.
Old Mar 2, 2018 | 01:32 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Originally Posted by MORREALE5
on new hinges
New or used? If you have a source for new please share.
Old Mar 2, 2018 | 01:17 PM
MORREALE5's Avatar
Car: 1987 IROC Z
Engine: L31 VORTEC
hey so new hood and new hinges, so reason for new hood was my old hood was bowed up in the middle from 30 years of opening and closing,reason for new hinges was the hood was hard to close and was all kicked sideways when open and closing.i installed new hood shocks today (advanced auto pn#e4422) and fixed all my issues,hood goes up and down straight,takes about 1/3 the down pressure to close the hood compared to old hood shocks,and the hood sits flat in the back,all my hood issues fixed with new hood shocks....the crazy thing is is my old hood shocks were only like 2 years old and worked as in holding hood up so i assumed they were still good but i guess not?...if you have any hood issues try new hood shocks even if it seems like the ones on your car work fine.
Chaotickriz
Sep 24, 2017 07:55 PM
jcs64
Feb 14, 2008 10:59 PM
daddydrake
Oct 8, 2006 10:23 PM
steve88iroc
Sep 29, 2006 09:17 PM
MdFormula350
Jun 17, 2006 05:46 PM
