Front bumper cover question
Old Apr 6, 2018 | 07:55 AM
theurge's Avatar
Car: 1985 trans am/ 1991 RS
Engine: 355sbc/ v6
Transmission: 700r4 automatic
Hey guys I've been trying to get rid of the gap between my hood and front bumper for years but no luck ever, I finally came to the conclusion that maybe the previous owner cut the lip for some odd reason maybe get more air to flow in for the carb, I don't know, can anyone take some pictures of there bumper to confirm this, ive looked online at trans am bumpers and it seems like they don't have that angle type cut in them but rather go straight up, hard to explain hopefully someone can help me out with this thanks
Old Apr 6, 2018 | 08:21 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Front bumper cover question
Take some better pictures? Looks like the hood is too far back, but need to see the whole front with the hood closed
Old Apr 6, 2018 | 08:28 AM
theurge's Avatar
Engine: 355sbc/ v6
Hope these pictures help
Old Apr 6, 2018 | 08:40 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
OK, so the hood is in the correct spot.
In your first picture, there are three screws visible. This bracket can slide a little bit. have you loosened all the screws all the way across and try to side it backwards?
There is also a vertical bracket that holds the cover to the bracket, there may be a little bit of adjustment there.
Also the whole latch support could be bent down. or the bumper bracket I said can adjust could be bent
Old Apr 6, 2018 | 08:47 AM
theurge's Avatar
Engine: 355sbc/ v6
Yes I have it as far back as possible. I was also missing that support bar underneath which I got and installed help raise it up the gap used to be half inch bigger with all the adjustments I've made I can't seem to lose that last half inch, so close,
but does it not look from the side that someone trimmed the top of the bumper cover when i look online at bumper covers i don't see a slant on the end just goes straight up?
Old Apr 6, 2018 | 08:53 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Did the car ever have an aftermarket hood on it??
Old Apr 6, 2018 | 08:56 AM
theurge's Avatar
Engine: 355sbc/ v6
While in my ownership never, but I don't know if somebody put one on before me
Old Apr 6, 2018 | 08:59 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
You can see it's slanted in these pictures too. Yours looks stock.
I had an accident in my 88 and it bent some stuff and I got a little bit of a hood gap afterwards. I think your brackets are just bent something
Old Apr 6, 2018 | 09:42 AM
theurge's Avatar
Engine: 355sbc/ v6
Take a look at this seems as if mine has be cut back or is my mind just looking for an excuse, if anyone could take a close up of the same area as mine that would be great, just want to be 100% on this
Old Apr 6, 2018 | 04:26 PM
aseychell's Avatar
Car: 1988 Trans AM GTA
Axle/Gears: 9-Bolt 3.27
Your hood is too far back. The headlamp doors should sit with their front edge in line to the fender to bumper line. From what I can see from the quite low quality photos, the edge of your headlamp doors sits further back meaning that the whole headlamp assembly and the hood need to move to the front.
Old Apr 6, 2018 | 05:04 PM
theurge's Avatar
Engine: 355sbc/ v6
I took some more pictures hopefully better quality, my phone sucks
i don't understand what you mean with regards to head light flaps, do you mean they have to be past the line that connect fender to front bumper or in line with it, because as far as I can tell they seem in line with it.
I took some close ups
Old Apr 6, 2018 | 05:59 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
It appears that car has been wrecked in the front before. The passenger headlight door is not lined up with the fender edge and the driver's side head light door is just a bit past the fender edge. The front bumper also appears to be shifted to the right (standing in front) just a little. Also, the gaps around the headlight doors are not the same on both sides. If this were my car, I would remove the hood, headlight assemblies, front bumper and fenders and start over. Take a good look at the front subframe supports under the fenders and the impact bar, you'd be surprised what you'll find when all of that is off.
Old Apr 6, 2018 | 06:05 PM
theurge's Avatar
Engine: 355sbc/ v6
The funny thing is I have removed everything I done this twice, maybe it was is a collision before I don't know, but from underneath and inside everything seems fine and identical to the drivers side, i did notice that the passenger side head lamp won't go any further forward to meet bumper but I guess I could wiggle it down more with some elbow grease, but i dont think it will help me get the bumper to meet the hood ?
Old Apr 6, 2018 | 06:17 PM
Car: 2 T-Tops
Engine: 327/305
Just from a cursory look from pictures, it would appear that both fenders need to slide back toward the doors. Do you have pictures of gap between fenders and doors and doors to rear jam?
Old Apr 6, 2018 | 06:40 PM
theurge's Avatar
Engine: 355sbc/ v6
Yes I just took some .the passenger side is exactly the same about 1/4 inch or less of a gap, that is continuous cant take pics of passengers side not much room plus it's snowing outside so yeah lol
Old Apr 6, 2018 | 06:51 PM
theurge's Avatar
Engine: 355sbc/ v6
Old Apr 6, 2018 | 09:27 PM
NoEmissions84TA's Avatar
From what I can see, your body lines and gaps are not that far off.
Guys, he is asking if someone sanded his nose in this area, causing that huge gap.
That angle (circled) is his reason for questioning. Is it supposed to be that way?
If it were mine, I would be asking the same question.
Attached Thumbnails Front bumper cover question-sanded-edge.jpg   Front bumper cover question-gap.jpg
Old Apr 7, 2018 | 12:09 AM
aseychell's Avatar
Yes mine also has that. You mentioned that the bumper didn’t have the brace and you installed it yourself. Are you sure it’s installed properly? It has to go behind the bumper not on top. You should have the 3x support strips on the outside. Not sure I am being clear. Perhaps you can send a photo showing the support brace bolted to the bumper?
Old Apr 7, 2018 | 12:13 AM
Drew's Avatar
Raise the center of the front bumper, lower the hood. Should be able to get almost all of that out by adjusting the hood latch, snubbers, and the front bumper cover.
Old Apr 14, 2018 | 09:10 AM
theurge's Avatar
Engine: 355sbc/ v6
Hey guys so just wanted to update you all on what I did and see what you all think, so as the previous poster mentioned I fiddle around trying to raise the bumper , I ended up using some 1/4 inch pieces of wood to shim the mental bumper holder I'll call it and lowered the hood latch a big more and ended up with this result
Old Apr 14, 2018 | 07:56 PM
Much better.
Grumbles
Exterior Parts Wanted
Mar 12, 2010 04:31 PM
robster66
Exterior Parts for Sale
Sep 25, 2009 05:36 PM
PyRo9862
Jun 4, 2008 10:59 PM
