Lower body paint code
Old Jun 26, 2018 | 11:15 AM
dsterling@roche's Avatar
Car: 1982 Trans Am, 1997 Grand Prix
Engine: Orig 305 Crossfire FI 36,500 miles
Transmission: original 200c THM
Axle/Gears: original 3.23 posi
1982 Trans Am, black upper body paint with gold lower body paint from the factory.
Does anyone know what the paint code is for the lower gold portion of the body?
Thanks, David
Old Jun 26, 2018 | 11:13 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Re: Lower body paint code
What does your radiator support tag say? There will be numbers similar to 15L 17U
The number with the L will be the lower one. If you can post that number with the L, I can look up the code on the PPG paint system at work and give you the WA paint code
My 82 Z28 shows the same number for each....so I'm not sure that number will get anywhere or not
Old Jun 27, 2018 | 10:37 AM
Thanks for the help.
My tag says 19L 19U.
Old Jun 27, 2018 | 09:06 PM
dagwood's Avatar
Top Answer: 1
19 is black. Figured that be a long shot..... I don't know how else to find it. I can try searching again tomorrow for a gold that was used from 82.
Old Jun 28, 2018 | 08:48 AM
I found that Gold Wing, 55/55E is a 1982 color. As I said my tag has 19L.
Thanks for all the help.
Old Jun 28, 2018 | 01:36 PM
IROC-MIKE's Avatar
Car: 86 Yellow IROC
Engine: 305 Carb
Transmission: 5 speed
IF your trim tag has the same upper (U) and lower (L) codes you have a monochrome paint scheme. Your example of 19L 19U means your car is Black Code 19 Upper and Black Code 19 Lower.
Old Jun 28, 2018 | 07:06 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
55 goldwing metallic WA-7568
Old Jun 28, 2018 | 08:01 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
This is incorrect on many thirdgens. They used the same code for upper and lower, and they matched the primary color of the car. In this case, black.
I found a code of 54 for the gold stripes used on the '82 Z28. Since the stripes are three color, I wouldn't use that unless you can confirm that it is the right color gold.
Old Jun 29, 2018 | 06:08 AM
I will check out the 54 code. Thanks everyone for your input so far.
Old Jun 29, 2018 | 07:06 AM
dagwood's Avatar
Top Answer: 1
I'll look today for ya
Old Jun 29, 2018 | 07:51 AM
Thanks dagwood
Old Jun 29, 2018 | 10:13 AM
dagwood's Avatar
Top Answer: 1
Almond Firemist. 1982 only. WA7398
Almond Poly 1982-1983. WA7474
GOLD WING POLY. 1982-1984 WA7568
GOLD WING POLY 1982 ONLY WA7739
That's all I could find for gold colors for GM in those years
Old Jun 29, 2018 | 07:24 PM
Thanks for your investigation. GM must want to keep it a secret!
Mark_ZZ3
Jan 30, 2025 01:34 PM
4mul8r
Oct 11, 2018 08:44 AM
Bald_eagle_machine
Oct 26, 2016 11:25 PM
z28cop
Sep 14, 2016 08:05 PM
