How do i know what style my camaro is?
Old Sep 26, 2018 | 11:48 PM
ChelseaHere's Avatar
Car: 86 Camaro Sports Coupe
Engine: 383 Stoker
Transmission: 700R4 transmission
Hi everyone! I just recently purchased my 86 Camaro. I absolutely love it however im not too sure what style it is. The title says CP under "style". But i don't know what that means... This is my first car and I don't know too much about cars, but I'm learning!
Old Sep 27, 2018 | 12:12 AM
the_assman's Avatar
Car: 90 vert
Re: How do i know what style my camaro is?
CP usually stands for "coupe"
Old Sep 27, 2018 | 12:32 AM
Engine: 383 Stoker
But aren't they all coupes?
Old Sep 27, 2018 | 12:52 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
yup.
Old Sep 27, 2018 | 01:18 AM
Engine: 383 Stoker
So it's just a standard coupe. Not iroc or z28, just standard?
Old Sep 27, 2018 | 09:19 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Yours is not an Iroc or Z28.
Old Sep 27, 2018 | 09:38 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
They were coupes and T-tops.
What engine does yours have?...
Old Sep 27, 2018 | 09:40 AM
jstadmud's Avatar
Car: 1987 IROC Z28
Engine: 5.0 liter
Transmission: 700R-4
Axle/Gears: 273 posi trac
I posted a reply on your "engine swap" thread in the "CARBURETORS" section that should answer some of your questions...
Old Sep 27, 2018 | 01:37 PM
Engine: 383 Stoker
I don't know. The previous owner built the engine so its kinda like a Frankenstein engine haha
Old Sep 27, 2018 | 07:19 PM
T.L.'s Avatar
I was referring to V-6 or V-8...
Old Sep 27, 2018 | 07:32 PM
Engine: 383 Stoker
I have no idea. How do i find out?
Old Sep 28, 2018 | 08:07 AM
jstadmud's Avatar
Car: 1987 IROC Z28
Engine: 5.0 liter
Take a few good pictures of the engine and post them here, we'll help you figure it out. Also, I left this link http://www.nastyz28.com/camaro/camaro86.html on your thread in "Carburetors' section. You can go there and use your Camaro's VIN# to find out what originally came equipped in your car.
Old Sep 28, 2018 | 05:30 PM
Engine: 383 Stoker
Here are some pictures!
Old Sep 29, 2018 | 10:52 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Thats a v8, but it may have had a v6 originally.Mostly likely a std coupe, maybe an LT variation depending on the yr.
Old Sep 29, 2018 | 02:31 PM
Engine: 383 Stoker
Can you tell me how you figured out it was a v8?? I don't know how to tell Myself
Old Sep 29, 2018 | 03:14 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Damn That Thing Has A Lot Of Pulleys On It.
Old Sep 29, 2018 | 03:33 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Mostly by the looks of it, you seen a few, you can tell right away, but one way is the number of spark plug (red) wires ( not the red electrical wires).Theres eight of them, another is how close the front of the engine is to the radiator, a v6 would have about a foot gap between the rad/eng.
Old Sep 29, 2018 | 04:18 PM
Engine: 383 Stoker
OH! Okay! That makes sense.. Thank you! Would you happha to know what engine it is?
Old Sep 29, 2018 | 06:47 PM
Engine: 383 Stoker
Pulleys? What are those for? Where do you see them
Old Sep 29, 2018 | 10:39 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
There are dozens of small block engines from chevrolet, so it could be anyone's guess.Mine would be a 350 small block, but there are still dozens of varieties of the 350.
Pulleys are the round things the serpentine belt is wrapped around.
Old Sep 29, 2018 | 10:49 PM
Engine: 383 Stoker
OH! Okay! Thank you so much for the information!
Old Sep 30, 2018 | 07:49 AM
TireSmokin''s Avatar
It's a pre-85 small block v-8. The only way to know what block and heads they are, is to look up the casting numbers.
But even then, they could have had work done to them, i.e. bored cylinders, or ported heads.
To know what the car was originally, you would have to decipher the RPO codes.
Old Sep 30, 2018 | 09:06 PM
jstadmud's Avatar
Car: 1987 IROC Z28
Engine: 5.0 liter
Frankenstein engine, looks like you might not be far off. The cylinder heads are pre '85. If the block is too, I would lean more towards 305 than 350 since it looks like the oil dipstick is on pass side. I'm thinking that serpentine setup is later than '85 for sure. From the position of the fuel line and vacuum hose placement I'm betting it has an Edelbrock carb under that air cleaner. Kickdown cable appears to be unhooked, not good if it's the 700r4 tranny. I like the A/C delete box, I still need to get one of those for my '83 Z28. Looks like it needs some TLC, how does it run? Is it strong?
rsc350
Jul 1, 2005 12:25 AM
FreeLoader
May 25, 2004 12:02 AM
Kontrax
Mar 5, 2004 10:29 AM
