Will Any 3rd Gen Doors Not Fit My '89 Formula?
Old Oct 26, 2018 | 05:42 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Any years have different hinges, latches, etc?
Old Oct 26, 2018 | 06:07 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
Re: Will Any 3rd Gen Doors Not Fit My '89 Formula?
I think there's only 2 things you really have to watch out for 1. is the early doors 82 thru...maybe 84, not sure, but they have a different front window guide and triangle that bolts to a completely different bracket not found on later doors with the one piece triangle/guide assembly. These doors take a two piece design, and the later triangle/guide will not bolt in there. However, if the early door comes with the guide and triangle, you can use it as is and you cannot tell the difference in appearance. 2. Doors with ground effects, you can still use them, but you'll have to weld up a bunch of holes along the bottom.
adamlinn13
Nov 29, 2012 10:20 AM
89fbrestor
Wheels and Tires
Dec 6, 2011 05:48 AM
Gmfirebird89
Exterior Parts Wanted
Jan 13, 2008 04:28 AM
Gib_Sandwich
Aug 1, 2001 10:02 AM
