Need to know what color this is
Old Jan 27, 2019 | 04:17 PM
DillonRager's Avatar
Like the title says, I need to know what color this is pic I have is an s10 but I think camaro came this color too, anyhow I want to paint my car this color . There is no metallic in it, the code is worn off the truck in the pic, I looked in the whay color to paint thread but didn't find it, thanks
Old Jan 27, 2019 | 06:43 PM
Abubaca's Avatar
Re: Need to know what color this is
I can't think of a Camaro blue that wasn't metallic. Could be wrong. ...either way, there's no for us to tell from the picture. Best bet would be to look through color swatches from a paint shop and choose that way. Or hit up and S10 forum.
Old Jan 27, 2019 | 06:50 PM
Abubaca's Avatar
What year s10? If it's original paint it shouldn't be hard to figure out the color.
Old Jan 28, 2019 | 06:28 AM
the truck is late 80s I'll have to ask the owner to know exactly. I do know that is original paint, I work in a paint shop and have been through every swatch we have for gm no luck, I'll check with my paint supplier
Old Jan 28, 2019 | 09:52 AM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
My guess is this color:
Old Jan 28, 2019 | 09:55 AM
Axle/Gears: G80 GU2
Or:
color looks different in lighting/snow but they are the only non metallic blues I saw for S10..
Old Jan 28, 2019 | 10:04 AM
Axle/Gears: G80 GU2
Not sure if a Camaro came in these colors unless it was a base or Berlinetta. I think the light blue RS was metallic.
Im not sure on base models pre 1985.
Old Jan 28, 2019 | 10:55 AM
Thanks, I'm gonna run those codes in the computer and see what I find
Old Jan 28, 2019 | 11:17 AM
The second one you sent is metallic , the first seems like it will be really light, I'm gonna mix a little and see later
Old Jan 28, 2019 | 11:29 AM
Axle/Gears: G80 GU2
It’s hard to tell from the pic because everything looks like it has a blue tint to it.. looks like the sun is going down..
light blue paint with blue afternoon shadow is deceiving..
I think Silverados and Sierras also had a non metallic light blue
Old Jan 29, 2019 | 09:57 AM
I had time today and mixed a little of the 9662 pastel blue and it is definitely too light, I'll get a few more pics of the truck but I won't be daylight when I'm home till the weekend. And it's hard to get a pic without snow here right now, here's a pic of the paint I mixed today
Old Jan 29, 2019 | 09:59 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
What the color code on the RPO or the body tag under hood?
Old Jan 29, 2019 | 10:11 AM
the code I usually use is in the glove box but too worn to read. Other than that idk the truck is pretty old I'll look around under the hood
Old Jan 29, 2019 | 07:51 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
If you can find out the year of the truck, you can then look up the available colors for that year.
Old Jan 29, 2019 | 10:19 PM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Transmission: Automatic
Old Jan 29, 2019 | 10:24 PM
Axle/Gears: G80 GU2
It’s tough because he said not metallic..
there was only only a couple blues from 80s-90s S-10 that weren’t metallic..
Old Feb 2, 2019 | 10:43 AM
BIRD91ZRAG's Avatar
The only non-metallic color blue I remember from back then was the dark blue. All the lighter blues, except maybe some special order colors, were metallic. I worked in GM body shops from 88-98, and 2000 until last year...
The metallic flakes used in those light blues was a fine or medium flake and once oxidized, they can look like a non-metallic color.
Old Feb 6, 2019 | 05:52 PM
Well, I feel dumb now, upon closer inspection there are very fine mettallics in the blue. Thanks for all the help everyoneLol
Old Feb 7, 2019 | 07:45 AM
Axle/Gears: G80 GU2
I was going to say.. that looks like a metallic color and those ones I found were the only non metallic.. Should be easy to figure out now..
Looks similar to an RS color.. IROCs didn’t come in a light blue like that..
FreeLoader
May 25, 2004 12:02 AM
Clint.D
Mar 23, 2002 11:06 PM
crazeinc
Jul 27, 2001 05:53 PM
