gauge ideas
Old Jan 8, 2002 | 10:03 PM
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
gauge ideas
My car doesn't have the computer in it any more. Because of this my gauges don't work. My speedo my tach and my fuel work my volt also. But my oil pressure and coolant temp don't work. How can I make them work. I would also like to put a higher mph gauge in my cluster. I have 85 mph. Can I change it? On another note my cruise control doesn't work either. How is that supposed to hook up to the carburetor?
Old Jan 8, 2002 | 10:58 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The gauges should work with or w/o a ECM. Unless the original gauge sensors (or senders, whichever you want to call them) aren't there or not plugged in, they should work.
The cruise needs a signal from the brown VSS buffer wire to work.
Old Jan 10, 2002 | 08:58 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
It depends on what engine you had originally, I had a 87 Formula with the 4bbl & I could unplug the ECM, and the gages would work. I looked at a car that was converted from TPI to old fashoned setup, carb etc... and I wanted to know if he would sell me the ECM, When I unplugged it, his gages stopped working. I re-installed it... they started to work again. His Temp & oil pressure gages stopped working.
John
Ghettobird52
Jul 5, 2024 11:18 PM
Derick15
Sep 17, 2016 05:28 PM
Wade787b
Sep 29, 2015 01:15 PM
BurlyChev
Aug 16, 2015 09:08 PM
