Damage Repair, need opinions on suspension damage
Old 01-09-2002, 12:13 AM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
Got into an accident last week.
Damage was front pass fender, pass door, and my front pass rim hit hers.
What I'm concerned about is the sudden shaking in the suspension. The suspension was top-notch before this happened.
The two BODY shops that gave me estimates said its prolly a bent rim.
I just went to a tire place today, and they said the rim's prolly fine, but its most likely a bald spot in the tire since I skidded. They also checked the front suspension and found nothing wrong (which almost shocked me since they "try" to find stuff whenever I go there)
Now this makes sense I guess. I can easily get the cost of a new GSC (245/50/ZR16) added to the insurance claim, and buy from CarnDriver or SLP, but i'm wondering... why would it JUST be the tire that hit that's got the flat spot?
As long as its reasonable or explainable to the insurance co, I'm gonna get ANY possible damage repaired on the car.
In short, my question is: should i suspect any other suspension damage or tire(s) damage?
I can clarify any points if I'm too vague
Thanks in advance guys
Old 01-09-2002, 12:40 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Why not jack the back end off the ground and see for yourself what it might be ? Spin the tire by hand and watch the tread. If the tread appears to have a dip in it at a certain point, it's probably a flat spot.
If the wheel itself wobbles, watch the center around the lugs. If they appear to spin in a flat circle & the entire wheel/tire wobbles, the rim is bent.
If the lugs seem to follow the pattern of wobble the wheels has (if it does..), you've got a bent axle.
Mutillator
Exterior Parts for Sale
01-02-2016 06:44 PM
Jlanz55
09-08-2015 11:28 PM
scottmoyer
09-07-2015 07:06 PM
84 TA NV
09-06-2015 08:02 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
Quick Reply: Damage Repair, need opinions on suspension damage
