Lower Side IROC Trim Piece Removal HELP!
Old Apr 1, 2019 | 11:15 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Got all the screws out from the sill and under car areas. Also removed hidden screws under emblem. Manual says to pull out and rotate up to remove piece from clips at rear of body. Tried that and afraid I’m going to break it. Any trick to removing this??
Old Apr 1, 2019 | 12:03 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Re: Lower Side IROC Trim Piece Removal HELP!
Never mind. There are no clips. Stud inside car with a speed nut on it. Info coming from GM Camaro Service Manual. 😡
Old Apr 18, 2019 | 12:28 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
That’s correct. You can get to it either by removing the speaker, or if you (or a helper) has small forearms, remove the vent in the door jamb and go in that way.
FL TA
Interior Parts Wanted
Mar 21, 2014 03:27 PM
scottwrightF1
Jun 18, 2010 07:37 PM
1986CamaroSC
Jan 28, 2004 11:26 AM
19doug90
Dec 15, 2003 11:14 PM
