Primer before painting engine bay?
Car: '89 Iroc
Engine: 383 TPI
Transmission: Built 700R4
Axle/Gears: 9 Bolt - 3.45
Have my engine out so figured it's a good time to paint the bay as well. I plan to clean and degrease and then am unsure if primer is necessary seeing as it's not going to be down to bare metal. Can it just be roughed up with some sand paper after cleaning and then painted? It will be going from factory dark red to black so coverage shouldn't be an issue, I'm just unsure regarding the need for primer or not. Thanks!
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Primer before painting engine bay?
Degrease it several times. Scuff it at least and then spray Epoxy primer.
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
I agree with Tibo.
A good epoxy primer for a good price is Omni MP170. You can mix it 2:1:1 (2 parts epoxy primer : 1 parts MP175 catalyst : 1 part Omni MR186 Reducer) and it will spray out like a sealer, and flash off fast. You can paint right over the top of it within 24 hours without having to scuff it. Omni is PPG's lower end line, but that epoxy primer is actually great stuff to work with. It calls for a 2:1 mix without reducer, but sprays heavier, and takes longer to dry. Mix it my way and you'll love the stuff. 1 coverage coat is all you need.
BTW I am a certified PPG painter at a body shop....been doing this a long time. If you have any questions, dont be afraid to ask
Car: '89 GTA
Engine: ZZ6TPI
I agree with Tibo.
Ca[maro]88
Feb 20, 2011 07:32 PM
rsrsrs
Sep 12, 2007 08:03 PM
87transam5.7tpi
Apr 15, 2002 03:13 PM
