Subframe connectors before LS Swap
Old May 11, 2019 | 07:27 PM
whostorm05's Avatar
Car: 1991 Trans Am
Hi Everyone,
I have a 91 Trans Am that I eventually want to do an LS Swap to. The car could really benefit from having subframe connectors installed. Is there a good reason why I should wait until after the swap to install the SFC's? Will it make anything with the swap harder if I get them installed now? During the swap the car is going to need all the related work done as well, exhaust, fuel tank, suspension, etc.
Is there a general consensus for the best subframe connections for these cars that you can actually still buy? I'm guessing weld in would be better?
Old May 12, 2019 | 04:32 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: Subframe connectors before LS Swap
Is your car already running and driving? IF so you can get the SFC install before you swap. Depending on what brand you get your factory exhaust routing may interfere. I have BMR inner sfc on my car.
Old May 12, 2019 | 05:37 PM
whostorm05's Avatar
Car: 1991 Trans Am
Yeah, car still has the stock setup and does run/drive. Not great, but it drives. lol Are these the ones you : https://www.hawksmotorsports.com/bmr...ors-bolt-weld/
Satisfied with them?
Anyone fans of Detroit Speed or UMI SFC's?
Old May 13, 2019 | 09:00 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Its never too soon to install SFCs.I have Global west perimeter & a very old (pre) Alston inner set, yes two sets on my vert.
Old May 13, 2019 | 11:00 PM
Car: 1984 T/A
Engine: LQ4
Yes thats what i have. the UMI ones i had on my old car as well. they are great. I am not familiar with the DSE sfc
Old May 14, 2019 | 10:51 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
My general advise it to always make the car better before making it faster. So SFC's and Brakes are first priority, then suspension, then anything else after that
Oh, and DSE SFCs are a great design and do not compromise ground clearance or anything else, but they are a lot more work to install than anyone else's. I put them in my car and would recommend them, if you can do the work yourself.
1992 Trans Am
Sep 4, 2017 08:36 PM
Mkos1980
Aftermarket Product Review
Jan 11, 2003 09:35 AM
RoadRocket L98
Mar 13, 2001 05:16 PM
JETHROIROC
Feb 3, 2001 09:56 AM
