Underbody Color
Old Sep 3, 2019 | 07:07 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Underbody Color
Anyone have any idea what the paint code or the name of the OEM underbody color is? Looking to do the underbody similar to the DSE Iroc. The exterior color will be black as is my rearend, suspension, and other parts. Want a contrast underneath with all the moving parts. Also will listen to reasonable opinions on underbody paint and pics if you have them. Final paint on my build coming soon.
Old Sep 3, 2019 | 07:53 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Re: Underbody Color
The underbody was exposed gray electrostatic (e-coat) primer with overspray from the outer body paint.
If you want to replicate that, light gray epoxy primer looks very similar to the factory e-coat.
if you are not going for the factory look, many people paint the underside semi-gloss black.
Old Sep 3, 2019 | 08:52 PM
steve40's Avatar
Re: Underbody Color
I used POR15 Grey, turned out fine...
Old Sep 3, 2019 | 09:37 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Re: Underbody Color
Did you brush or spray it and if sprayed, did it smooth out or is it rough? Hard to tell in pic.
Old Sep 4, 2019 | 08:07 AM
steve40's Avatar
Re: Underbody Color
It's brushed. There are some rough spots but not bad for the underside. Key with por, use lots of brushes, as the paint builds up, it shows more strokes
Old Sep 5, 2019 | 09:10 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Re: Underbody Color
Interesting, thanks for the detail on the e-coat. Do you know if the factory applied some sort of waxy rust proofing on hidden, inner panels? I'm noticed something inside my doors which is sort of clear, waxy that could be rust proofing. Seems like there is too much to be dried up grease.
Old Sep 5, 2019 | 09:49 AM
Car: '89 GTA
Engine: ZZ6TPI
Re: Underbody Color
I didn’t find any waxy inner coatings in my 1989 or my previous 1986 thirdgens. There were many dealer applied rustproofing products back then and many were a wax type. That would be my guess.
The undersides had no undercoating from the factory, but many were under coated at the dealer (especially northern cars).
Old Sep 5, 2019 | 11:04 AM
LiquidBlue's Avatar
Transmission: MD8
Re: Underbody Color
The car came from a Houston area dealership. I would think the dealership applying some sort of rust protection would be slim to zero chances. I've read about rust protection that is described like this, just never have seen it before. Seems like it would also be something GM would not concern itself with - too expensive.
Old Sep 5, 2019 | 09:31 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Re: Underbody Color
Most dealers in Houston sent cars to Ziebart for rustproofing. Nasty tar crap. Then GM had one called Rusty Jones rustproofing. More like what you described in previous posts.
Old Sep 5, 2019 | 09:54 PM
Saxondale's Avatar
Car: 84 Z
Re: Underbody Color
Likely a wax based product is present. Both my 87 and 84 Camaros had it in the engine compartment, which rewuired mild solvents snd elbow grease to remove.
Old Sep 5, 2019 | 10:10 PM
LiquidBlue's Avatar
Transmission: MD8
Re: Underbody Color
ive noticed something similar at the hood hinges. but attributed it to dried out white lithium grease
Rondeezzee310
Mar 4, 2012 04:49 PM
pondriver
Sep 9, 2006 08:53 PM
Tger
Oct 23, 2004 07:19 PM
90FormulaWS6
Aug 24, 2004 04:40 AM
Twistopher
May 14, 2002 04:09 PM
