Any tips for installing window weather strip?
Old Oct 7, 2019 | 08:48 AM
Camarillo's Avatar
Car: 1990 RS Camaro
Engine: 1990 305 tbi lo3
I recently installed new door and window weatherstrip. I hear a lot of wind noise now. I did not glue in the window weatherstrip. I noticed that the original weatherstrip that I pulled out of the window areas had some sort of adhesive or like glue in some areas. I was wondering if I’m supposed to caulk, glue, or apply some adhesive to the window weatherstrip to create an actual seal?
Old Oct 11, 2019 | 08:06 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Any tips for installing window weather strip?
RTV silicone works well, but some weatherstrip holds well w/out it.
Old Oct 15, 2019 | 10:26 AM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
A lot of 4 letters words for me, and I am not done or happy yet. So the verdict is out if cursing helps.
Old Oct 21, 2019 | 06:22 AM
82tarecaro's Avatar
Cursing helps. Beer helps too.
Old Oct 21, 2019 | 08:24 AM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
I use a little bit of black RTV when a weatherstrip doesn't stay put.
Two neat tricks I've learned over the years from old timers that may help..
1 One way to help locate wind noise/air leaks is to grab yourself a cheap stethoscope, then find a station on the radio that has steady static and turn it up loud and close the car up. Then you can run the stethoscope along the weatherstrip and find your air leak where the static gets louder.
2 once you find where its not sealing properly, pick up a pack of tire plugs(the 6" or so long strips of rubber covered in sticky glue) and use it to bulk up the weatherstrip. But that only works on ones where you can actually tuck it into the weatherstrip, doesn't work in every situation but may help you out. Hope that makes sense.
Green89IROC305
Feb 5, 2014 08:44 AM
Firebat
Dec 17, 2011 11:00 AM
slia67
Apr 20, 2009 02:38 PM
86irocterror
Jan 15, 2007 03:11 AM
